Drover Posted November 26, 2019 Share Posted November 26, 2019 Hey guys appreciate any help advice, I have a 2006 ford Fusion. Just took it to the garage today to get them to investigate tyre wear on outside rear of 1 tyre they couldn't find anything wrong but also say it's not possible to do rear tracking on this model? Surely that's not correct? Confused.com 🤨 Quote Link to comment Share on other sites More sharing options...
iantt Posted November 26, 2019 Share Posted November 26, 2019 They are right. It's a solid twist beam axle. Did they check the rear tracking anyway to assertain if the tracking was out. Has that tyre always been in the same position or been on the front at some point? Quote Link to comment Share on other sites More sharing options...
Drover Posted November 26, 2019 Author Share Posted November 26, 2019 2 minutes ago, iantt said: They are right. It's a solid twist beam axle. Did they check the rear tracking anyway to assertain if the tracking was out. Has that tyre always been in the same position or been on the front at some point? The tyre has always been in this position and is 3 years old with 30,000 miles on it. The inside has 3mm+ on it and outside has 1.5mm Not sure if they checked it but if it's not adjustable is there any point? What could they do? They said could be a twisted chassis or something else twisted? 🤔 Quote Link to comment Share on other sites More sharing options...
iantt Posted November 26, 2019 Share Posted November 26, 2019 Could be a bent stub axle( the bit the drum attached too. ) I personally would worry if there's only 1.5 mm difference, just put another tyre on and drive it for another 30k . Quote Link to comment Share on other sites More sharing options...
Drover Posted November 26, 2019 Author Share Posted November 26, 2019 21 minutes ago, iantt said: Could be a bent stub axle( the bit the drum attached too. ) I personally would worry if there's only 1.5 mm difference, just put another tyre on and drive it for another 30k . Yes I think your right, might end up worse than it is. Quote Link to comment Share on other sites More sharing options...
ThomWatt01 Posted February 25, 2022 Share Posted February 25, 2022 Robust tire alignment is important to avoid excessive wear on tire and vehicle parts. Poor tire alignment can make wheels work against each other and can also decrease your MPG. Here are some signs that scream that your car needs a serious overhaul- Uneven wear Passive pulling Vibration A crooked steering wheel 2 Quote Link to comment Share on other sites More sharing options...
unofix Posted February 25, 2022 Share Posted February 25, 2022 I guess tyre pressure is unimportant ? Quote Link to comment Share on other sites More sharing options...
FredRT Posted October 18, 2022 Share Posted October 18, 2022 On 11/27/2019 at 1:57 AM, iantt said: Could be a bent stub axle( the bit the drum attached too. ) I personally would worry if there's only 1.5 mm difference, just put another tyre on and drive it for another 30k . My friend is looking at this neat Ford Fusion but also showing uneven wear signs on the passenger side. Otherwise, it is totally neat. We'll just finish installing the rotors and kmc wheels on the F150 this week before we take a closer look at it. 1 Quote Link to comment Share on other sites More sharing options...
