Rootriver Posted January 20, 2020 Share Posted January 20, 2020 Hello all! I have a 2008 mondeo with 1.8 Tdci. First my EGR gave fault codes and then the car started to refuse igniting when motor was hot after few weeks. I blanked the EGR, and the problem got little better (ignites better as the air is purer?), but still refuses to ignite properly. The engine kind of ignites but then stalls. I had the plugs replaced 2 years ago. Obd shows that rpm is pretty much same hot or cold as is fuel rail pressure when trying to ignite. Ignites like a charm every morning and after work, but I cannot go to shop, as the car won't start. The car will also start nicely when towed (its manual). Car also runs fine when hot, once I get it running. So any ideas? Anyone had same problems? Is it the EGR? Injectors (car has VDO injectors)? Fuel pump? Thanks for your help! Sent from my ONEPLUS A6003 using Tapatalk Quote Link to comment Share on other sites More sharing options...
