aquariusblue Posted March 1, 2020 Share Posted March 1, 2020 Changed fuse and bulb, no dice. Where would I find this switch I've been told about? Thanks in advance for the help. Quote Link to comment Share on other sites More sharing options...
nicam49 Posted March 2, 2020 Share Posted March 2, 2020 On the gearbox, I'm guessing, as it it on the Mondeo mk3 1 Quote Link to comment Share on other sites More sharing options...
isetta Posted March 2, 2020 Share Posted March 2, 2020 not 100% certain but I reckon it's on front of gearbox. if you stick you head under front bumper and look at front of gearbox it should be there. when I had same problem on my focus mk1 it just needed the plug on the switch prodding a bit and reverse light came back to life. Once I found that was where the problem lay I unplugged it and put some wd40 and pushed the connector on and off a few times. it was fine after that. Of course it's nice to have the light working but on a car of that age it's not part of the mot test (it is on newer cars) 1 1 Quote Link to comment Share on other sites More sharing options...
aquariusblue Posted March 4, 2020 Author Share Posted March 4, 2020 Thank you so much for the help, I have since located it and will work on it when I can get into my bonnet. Quote Link to comment Share on other sites More sharing options...
