GradyR_ Posted June 2, 2020 Share Posted June 2, 2020 Hello, i have recently had some issues with my 2013 fiesta ST randomly throwing up an engine malfunction error and a little spanner come up on the dash. I’ve had some diagnostics done today and these are the error codes the car is showing: P006A:62-6C - Manifold Absolute pressure P115E:97-68 - Throttle Actuator Control Throttle Body Air Flow Trim At Max Limit P1935:82-28 - Brake Switch/Sensor Signal P2121:86-28 The person that came to do the diagnostics thinks it may mean the throttle body needs replacing, just wanted to see if anyone on here had experienced anything similar and what they did to resolve it. The lights clear off as soon as I turn the engine off and back on again and then it drives with no issues. Thanks Quote Link to comment Share on other sites More sharing options...
Luke4efc Posted June 3, 2020 Share Posted June 3, 2020 I take it the guy cleared the codes using the obd2 scanner and they've come back straight away? The throttle body or map sensor may just need a clean. If it's driving without issues then I'm not sure they need replacing. Certainly try the cheap option of cleaning before you go replacing bits. Quote Link to comment Share on other sites More sharing options...
GradyR_ Posted June 3, 2020 Author Share Posted June 3, 2020 3 hours ago, Luke4efc said: I take it the guy cleared the codes using the obd2 scanner and they've come back straight away? The throttle body or map sensor may just need a clean. If it's driving without issues then I'm not sure they need replacing. Certainly try the cheap option of cleaning before you go replacing bits. Yeah he cleared the codes yesterday and Then today I had the light come up again. Gonna try get the sensor cleaned and see if that makes it any better. thanks Quote Link to comment Share on other sites More sharing options...
Edgar76 Posted February 25, 2021 Share Posted February 25, 2021 On 6/3/2020 at 5:15 PM, GradyR_ said: Yeah he cleared the codes yesterday and Then today I had the light come up again. Gonna try get the sensor cleaned and see if that makes it any better. thanks HI mate, did you resolve this issue? Quote Link to comment Share on other sites More sharing options...
