LukeG99 Posted June 20, 2020 Share Posted June 20, 2020 I got a quote for a carbon clean for £75 my car has 150k+ mileage so I think it might help the engine out, what do people think? Quote Link to comment Share on other sites More sharing options...
isetta Posted June 20, 2020 Share Posted June 20, 2020 do you have a problem that needs fixing? what does this carbon clean comprise of? is it just putting some fluid in fuel tank and then telling you to thrash it? can you explain more. Quote Link to comment Share on other sites More sharing options...
LukeG99 Posted June 21, 2020 Author Share Posted June 21, 2020 15 hours ago, isetta said: do you have a problem that needs fixing? what does this carbon clean comprise of? is it just putting some fluid in fuel tank and then telling you to thrash it? can you explain more. I think it's where gas it put though the engine and its suppose to take away carbon deposits from combustion, my engine just seems a bit rough and it seems a bit unsmooth when at low speeds. Quote Link to comment Share on other sites More sharing options...
south_bound Posted June 21, 2020 Share Posted June 21, 2020 I think you need to find out some more information on what this so called carbon cleaning is before anyone can advise. I have sen some writeups on terraclean which sound positive, maybe you could look into that in more detail? Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted June 21, 2020 Share Posted June 21, 2020 Worth it as in will you save £75 on fuel from doing it? Absolutely not... Worth it for the placebo effect that some people feel? Only you can decide that... Quote Link to comment Share on other sites More sharing options...
LukeG99 Posted June 21, 2020 Author Share Posted June 21, 2020 1 hour ago, TomsFocus said: Worth it as in will you save £75 on fuel from doing it? Absolutely not... Worth it for the placebo effect that some people feel? Only you can decide that... Yeah I certainly feel like it would just be a placebo after talking to others but it's nice to know what other guys think Quote Link to comment Share on other sites More sharing options...
Bongo2296 Posted June 21, 2020 Share Posted June 21, 2020 I had mine done, didn't feel any difference. I did see the guy spray some go go juice in the intake to make it feel a little different when I first drove it, after that wore off it went back to normal. Still had the usual Mk2 TDCI DPF problems after the procedure. Quote Link to comment Share on other sites More sharing options...
south_bound Posted June 21, 2020 Share Posted June 21, 2020 1 hour ago, Bongo2296 said: I had mine done, didn't feel any difference. I did see the guy spray some go go juice in the intake to make it feel a little different when I first drove it, after that wore off it went back to normal. Still had the usual Mk2 TDCI DPF problems after the procedure. Sounds like you were sold good old fashioned snake oil! There is only one reliable way of dealing with the Mk2 DPF problem imo, but not many want to recommend it nowadays. Quote Link to comment Share on other sites More sharing options...
Hooded Posted June 21, 2020 Share Posted June 21, 2020 If it ain’t broke don’t fix it. Not something I’d waste money on if the cars running sweet. Quote Link to comment Share on other sites More sharing options...
Ennvoqation Posted June 21, 2020 Share Posted June 21, 2020 From my experience carbon cleaning can help but only if you do it properly by doing a strip and clean, but it should be done alongside other engine maintenance such as oil flush (engine, clutch and/or diff), EGR cleaning etc. This is only really recommended on high mileage vehicles or, if you're concerned, on a vehicle you've bought that you're unsure of it's history. If you have power delivery issues, then looking at fuel filters/injectors or sparks and fuel lines is recommended as well. However if it's a relatively modern engine they run pretty clean these days, especially if you fill with 'clean' fuel. Supermarket fuels tend to run dirtier as they don't have the same additives added to help the engine run smoother (and yes, I know the controversies of supermarket vs oil companies)of course this can be offset by using your own fuel additives such as BG or Liquimoly and that's arguably better than getting carbon cleaning. 1 Quote Link to comment Share on other sites More sharing options...
LukeG99 Posted June 22, 2020 Author Share Posted June 22, 2020 Thanks for your insights guys. I don't really see the point either now. Quote Link to comment Share on other sites More sharing options...
