PRESSURES !
Hi Ford Ka owners mine is 2014 , but have been told several different pressures front & back to what manual says ! Does anyone REALLY know ?!!! , kind regards ,
Debbie
What dose the label stuck on the car say they should be ?
Well I'm going to assume you mean tyre pressure here.
The fronts are different pressure to the rear, and both those pressures change depending on what size tyres you have fitted. Then the pressure will also vary depending on how much weight you are planning to put in the car.
As said above, the label on the inside of your door will tell you what pressures you should to be at.
If you can't be bothered to do all that then a general rule of thumb for most normal cars is 32psi on the front and 30psi on the rear. Unless you're an eco-mentalist it'll be fine at that.
