Fuel filter replacement.
I've just replaced my fuel filter but the process could have been easier. I'll explain. I drove the rear end up onto ramps and shuffled under. The old filter was held on with cable ties as the clamp was long gone. I cut off the cable ties, disconnected one line then the other, then re-secured the new filter - no leaks - happy days.
As I was shuffling out of the petrolly atmosphere under the car I realised that the filter is so much more accessible from the nearside side of the car where you can lie down not under the car and access everything so much easier - you can see the filter just behind the rear edge of the door inboard a bit. Today's tip - don't get under if you don't need to! Cheers.
