Sharikins Posted September 3, 2022 Share Posted September 3, 2022 I have an intermitent fault on my 2006 focus TCDi. It often cuts out when I go to put in reverse gear, and often cuts out when I'm driving along. I have had the fuel valve pressure regulator control valve changed, which hasn't made any difference. Any ideas on what this could be would be great. Thanks Sharon Quote Link to comment Share on other sites More sharing options...
unofix Posted September 3, 2022 Share Posted September 3, 2022 Well you have come to the right place if it's an answer from 'Guess Olympics' you're after. If you want to perhaps stand a chance of a more accurate answer then download FORScan on a laptop and have a check for any Ford specific DTC's on your car. One quick question, does the instrument cluster seem to behave correctly or do you get random warnings from time to time? Download FORScan (free for laptop use): https://forscan.org/download.html ELM327(modified) connecting lead: https://tunnelrat-electronics.fwscart.com/USB_Modified_with_switch_ELM327/p4541936_17045457.aspx Quote Link to comment Share on other sites More sharing options...
Sharikins Posted September 3, 2022 Author Share Posted September 3, 2022 1 hour ago, unofix said: Well you have come to the right place if it's an answer from 'Guess Olympics' you're after. If you want to perhaps stand a chance of a more accurate answer then download FORScan on a laptop and have a check for any Ford specific DTC's on your car. One quick question, does the instrument cluster seem to behave correctly or do you get random warnings from time to time? Download FORScan (free for laptop use): https://forscan.org/download.html ELM327(modified) connecting lead: https://tunnelrat-electronics.fwscart.com/USB_Modified_with_switch_ELM327/p4541936_17045457.aspx The instument panel seems ok, no warning lights. Quote Link to comment Share on other sites More sharing options...
