Ford Focus MK4.5 2022+ issues thread
1 hour ago, unofix said:
I think we've had a recent thread about such things 🤣
Apologies I just found the thread 🤣. With LED headlights, do we need to put the stickers on them whilst driving on the right in Europe or are they not required with that type of light?
  • Replies 277
  • Views 72.4k
  • The Keyless entry gets disabled on the passenger door(s) once the State Of Charge reaches or falls below 55% When the battery SOC recovers then the keyless entry automatically gets restored to th
  • Looks like Dendritic growth to me. This is a naturally occurring phenomenon common to alloys such as aluminum. It is totally harmless and once the entire surface is covered in the greyish white powder
  • I feel like this should just be your signature at this point. 😆
Yes you will still need the corrective stickers for your lights, just like with traditional headlights. 👍
8 hours ago, Alex.S said:
Great but how much does it cost? Per gb ?
At the moment £0
there refreshing the tariffs so I’ve got a good will bolt on. 👍
About Amazon Alexa, what’s the point? There’s not much it can do   that your phone can’t. I use Siri , I avoid google maps cause it can’t do voice controls on Apple CarPlay afaik. I’ve got a dot in the house to stream music or ask what year it is.. only virtual assistants in my car are Siri and Ford nav .. that’s plenty!
Most of our house is either Alexa or Siri.  So having Alexa in car for me is a win win.  Control more of the heating etc.
15 hours ago, Daz-UK said:
At the moment £0
Mk4 had something like 60gb complimentary from new , I’m not even sure what I used it on as I’ve plenty data on my phone.. 🧐
What use have you found for it?
For me, I’ve been using it with iPad or family members connect to it when they run out of data.
just use it for anything really while I’ve got it for now. But it does come in use on long journeys or say my own network may not have a signal and the car has.
New issue - the price!
Have recently looked at quotes to trade in my 2020.75 ST Line X in for a new 2023.25 ST Line X and the price is up over £5.5k from what I paid for my current one.
I know inflation, cost of energy etc. but I can't see the justification for such a price hike.
I had hoped to just swap (as seamlessly as possible) into a new Focus, but I'm starting to look elsewhere now! 😞
This is not Ford/Focus specific, this is a problem with the entire car market..
They want us to switch to boring electrics that are ,,environmental friendly" but they don't care about high cost to purchase this vehicle, slow charging time, high cost of battery replacement and so on.
  • 3 weeks later...
Just FYI.
Had the screen chequerboard issue with sync 4 today. Happened during driving, and soon settled down, but pattern remained in some small areas.
Ign cycle didn't sort it.
Stayed outside 8hrs at work, and was fine when next started up, so a full sleep of sync was required. Fine on the way home, 1.5hr journey
I would assume there is a button combo to force restart sync like there is with sync 3.
Yeah, its on the Internet somewhere,
I think its the same as sync 3. On off button and next track for 5 secs, something like that.
Only you have to use the steering wheel next track button.
I went on a gravel road in the weekend with my car and the shield underneath the car was broken, so I went today at the mechanic, and they said I need to replace the engine shield... The original shield it's made of felt and it's a bad quality one, so be careful guys...I don't understand why people want cars with low ground clearance when you can easily make mistakes like mine..
I bought a metal one instead, here in Romania was 90 euro, I hope I'll not have any problems with it...
Update: the metal shield couldn't be mounted by the local Ford service because ,,it has some security issues and it could be easily falling.."
I asked for a Sync4 update and they said that for my VIN there is no update available which it's really annoying.... New delivered cars are coming with the new Sync while the old ones are  still stuck on a very bad version...
I've asked for this and they said to me ,,we don't push updates based on customer request."
Are there known good and bad versions of Sync 4? Would be curious to see what mine is.
21333 bad version
22xxx good version with fullscreen Android Auto/Apple Carplay
1. Just spotted what looks like corrosion on a bracket near the engine. Also spots of it nearby on the metal below the red circle on the first photo below. Bought the car 6 months ago, new. It was made, I believe, in March or May 2022. It's a hefty, thick part, so it's not going to cause a problem any time soon. But why is it there, and so soon? I don't live near the sea, I regularly clean the car, including underneath, and everything else is fine. It rubs off on your fingers, but not entirely off the bracket. Anyone else experienced this?
2. (Minor point) When using cruise control, the speedo needle matches the digital readout. But when not in cruise control (most of the time for me) the digital readout often displays a speed which is one and often two mph higher than the needle. For example, the readout says 32 or 33mph and the needle is barely above 30mph. Didn't notice it on my previous Focus, a Mk4.
3. (Very minor point) My PDF warranty document says "before any Warranty work is carried out to Your Vehicle, produce Your Ford Service History Log duly stamped..." Logs no longer exist in paper form. I even tried to buy one, after buying the car. And the document says "All parts which are replaced under this Warranty shall belong to Us." Puzzling.
Just means the failed parts that are no longer fitted to your car (ie they have been replaced). You own the NEW parts but not the old parts.
On 4/9/2023 at 7:52 AM, Chera said:
21333 bad version
Thanks. I, too, am on the old version then.
I don't think Ford pushed an update for the old cars(built before Oct 2022), they don't even care about doing this, they're shipping only the new cars with the new builds, otherwise, I think we'll see this update in the Q4 if we're lucky...
Thanks. That makes sense, of course.
I wondered if anyone else has experienced this corrosion on their vehicle? And if so how old is your vehicle? Going to get it checked at a dealer next week, but thought someone else may have experienced something similar. Not the sort of thing I'd expect on a car a year after its manufacture, but I could be wrong of course.
I'm not sure that is actually corrosion.  Have you tried wiping it off?
Looks like Dendritic growth to me. This is a naturally occurring phenomenon common to alloys such as aluminum. It is totally harmless and once the entire surface is covered in the greyish white powder the process stops as the oxidization of the surface of the alloy is protected.
This is the reason that you can't paint aluminum alloys or steel that is galvanized without first using an etch primer.
Dendritic growth also occurs on electronic circuit boards which have traces of organic flux residue remaining after the solder process. In these cases the dendritic growth eats away at the copper tracks and component leads and if not cleaned away it leads to failure of the board.
Thanks so much for this. I'm reassured now. I also noticed it on a relation's 2008 A3, covering most of the aluminium parts, but perhaps not quite as thick. But maybe it just looks a little thicker/worse at the moment on mine because it contrasts against the surfaces which don't yet have the growth.
Before posting, I rubbed a very small part of it and it wipes off a bit onto your finger, but most remains on the metal. Unofix's reply below yours was very enlightening.
