Jubly Posted April 4 Share Posted April 4 Hi, my mileage display no longer works which means it won't pass the MOT. I've been told by my local Ford Dealer I will probably need a new instrument cluster which is expensive. Is there anything else it could be before I jump into paying for an expensive bit of kit to be fitted? Ideally, I'd like to go to my dealer sounding like I know what Im talking about and make other suggestions first. Any help is greatly appreciated Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted April 4 Share Posted April 4 18 minutes ago, Jubly said: Hi, my mileage display no longer works which means it won't pass the MOT. Hi, it should pass like that. The speedometer must work, but there's no 'reason for rejection' covering the odometer as far as I'm aware. The fix most likely will be a replacement cluster. However this can be done by an independent, with a second hand part, as long as they have the tools to adjust the mileage on the replacement. Quote Link to comment Share on other sites More sharing options...
DaveT70 Posted April 4 Share Posted April 4 Is it law to show mileage? I thought not? Ask an MOT tester, before you splash out. You could get a replacement 2nd hand cluster and use that, but it would need programming and reconfiguring (something Ford CANNOT refuse to do) once you've fitted it. Or you could ask one of the repairers on eBay that fix the MK2 Focus Clusters if they could repair yours, I bet they can 1 Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted April 4 Share Posted April 4 Don't ask an MOT tester! Or if you do, ask for the specific RFR. I've had several issues with testers not understanding the wording in the manual and failing things they shouldn't. Sadly it relies on having a good understanding of the English language, not everyone does. Quote Link to comment Share on other sites More sharing options...
Jimpster Posted April 4 Share Posted April 4 at the risk of repeating myself and seeming like a fan club, go on facebook and look for Richard Arron Beetwell or Ollie jones they do these repairs every day can even supply a replacement cluster, Richard did mine for £120 instead of the £1000+ Ford wanted, and no messing with mileage issues. 1 Quote Link to comment Share on other sites More sharing options...
Ecosport2019 Posted April 20 Share Posted April 20 I can confirm you do NOT need the mileage displayed, only the speedometer and it must also illuminate incase that doesn't work. Oh and other warning lights obviously have to work 1 Quote Link to comment Share on other sites More sharing options...
