jane_b Posted February 16, 2012 Share Posted February 16, 2012 hey i found something intersting on some russian forum i hope someone can translate and make a how to http://ffclub.ru/topic/74863/#entry2604337 just a good idea :D:D:D Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted February 16, 2012 Share Posted February 16, 2012 Be warned - it's a load of gobbledegook. Good luck. Top of Form I plan to put on each door, two flashlight: A. Red - to the ends of the casings of doors to other drivers in the dark could see the position of the open door. Two. White - the bottom of the skins to see in the dark to attack, getting out of the car. To do this, bought four VAGovskih red lantern (mounted on the ends of Audi's door skins), and four white torch light luggage Focus hatchback. I want to make the inclusion of each door separately, ie, what door you open, on the lanterns and lights, while the remaining zakrtyh do not burn. For this connection to find 12V analog signal from each door separately. As I understand it, the signal to open the doors give the castle, and a complete set of doors Ghia, this signal is on tsiforovoy bus. Thought for connecting lanterns to put CAN-module, but the instructions written that CANy give a separate signal only the driver's door and other doors all together. There is the idea to put limit switches in the front door, but something did not really want to drill and kalhozit Fedka. Can be those who have ideas on how to be plugging in the Ghia lanterns each door separately? # Edited: Pyzhik, February 25, 2010 - 21:32 FF2 door. door lights, lanterns, lights in the cabin Posts: 422 | Views: 72,036 | Link Pages: 123 ... 11> Mamok November 14, 2007 - 22:46 # A It is unclear why this is the standard does not shoved into Givi. Deon November 14, 2007 - 22:50 # A I also do not understand! The car did a decent, and the details of kopeeshnoy saved! .. :: STudent :: .. November 14, 2007 - 22:55 # 0 I have a trend with 4 lifts EFTA lights okolodvernogo space mirrors ............. one of the described functions they serve you in the pool does not occur Mamok November 14, 2007 - 22:56 # 0 Hmmm. And what a Givi tada it not? UO can be good for? .. :: STudent :: .. November 14, 2007 - 23:10 # -1 Mamok trend of taxis in Gia for her extra charge 290 ye sanekk November 15, 2007 - 9:42 # 0 I know how! I've thought about it. These lamps must be connected to the door module to the terminal, which activates the backlight okolodvernogo space (number of contacts are looking for in the subject set in the mirror turn signals). But the question is, when you open the left door, mirror on the right torch is lit, too? Will there be some sort of reaction to the back door of the door module (or only function is implemented in the front)? All should try to ... kamena November 15, 2007 - 10:08 # 0 QUOTE (Deon @ Nov 14 2007, 23:42) I want to make the inclusion of each door separately, ie, what door you open, on the lanterns and lights, while the remaining zakrtyh do not burn. And why so basically, let burn all need not rack your head, connect the lights on the legs and everything! I'm so energized with light rapids and I was not how much breaks off the fact that others also lit at the opening of a door, you still can not see them! Also wanted to highlight in the door, but forgot to buy a ceiling lamps, before sizing machine, then again, did not want to disassemble the casing. sanekk November 15, 2007 - 12:24 # 0 Deon And how much money is worth flashlights? And I did everything I wanted with the car, and now boring, itching, I want to take up the lanterns. skipiribiba November 15, 2007 - 12:27 # 0 Does anyone know: a default in the solid trend is wiring for the lights okolodvernogo space? sanekk November 15, 2007 - 12:54 # 0 skipiribiba No. Moreover, there is even a module to control it (unless you have all 4 power windows). Alexx72 November 15, 2007 - 13:53 # 0 Mamok I ordered lights in the mirrors of the option-manager warned that this option may be incompatible with the "Gia" in principle The car came without this option. . (The rest of the bunch was present) The search led to the fact that of.diler said, installing lighting, it is necessary to start a door CAN-bus, ie This section of the wiring is different in "Gia" and "trend". In general, the dealer does not come from behind ... I agree that could be in "Gia" this option and leave the business-that- Gidropon November 15, 2007 - 14:20 # 0 Good people! Tell me, where you can set the backlight okolodvernogo space? -Volk-November 17, 2007 - 23:18 # 0 QUOTE (Gidropon @ Nov 15 2007, 13:20) Good people! Tell me, where you can set the backlight okolodvernogo space? Ask, and you agree to establish a service neofitsalov. Jennik1 November 17, 2007 - 23:41 # 0 As for where to install - I do not know How to install but the answer - as a Scorpio Ghia - just perfect the mechanism of think fit and, most importantly it = specials. thought h lights .... and fixtures sanekk November 18, 2007 - 12:17 # 0 Alexx72 Just the same, if you Gia, the installation of lighting and perhaps only here. Only ubb have door modules, which connects lights. Look for additional equipment to the topic how to do it, there's not much to read. No Fear November 18, 2007 - 12:58 # 0 Deon Look here http://foto.mail.ru/mail/muzzy2001 I am currently doing on the 3-door hatch. Put lampshades on VW TOUAREG white and red. Powered by a light foot and pulled the wires in the door. Goes along with regular backlight shades gradually. Deon November 18, 2007 - 15:44 # 0 No Fear For your reference message: "Unfortunately, the pictures you requested is not available" Jennik1 Can be a little more out there that a different mechanism for such a Scorpio Ghia? Deon November 18, 2007 - 15:59 #0 QUOTE (sanekk @ Nov 15 2007, 11:24) Deon And how much money is worth flashlights? Red 322 rubles per Thing. They are built with patronchikami and lights. Not very cheap, but nothing suitable in quality and an external view of the domestic avtofonarproma I neshel. We establish these lanterns on VW and Audi. They come in red and white. With the help of whites can podvsetit space under doors. But in the bottom of the door I bought a Ford, they are unloaded, the price of 133 rubles. a little thing. Patronchiki them bought Yuzhke to 15 rubles. malenkiy November 19, 2007 - 23:42 #0 Deon zapytyvaete both ceiling on the relay if ka UTB lights lkolodvernogo space and sewed it ... Jennik1 November 20, 2007 - 0:08 #0 Deon The mechanism is such that - 5V lamp is inserted into the base and twisted on the floor turn into a flashlight everything is very tightly (I even tried the water again), and reliable. There can be no closure, there can not get damp and dust, ... I'm on Skorpen stand - in the evening really helps * a * = a spotlight people think that Lincoln podehat))) The most important thing - they were made for this plant! And the price of = - for any disassembly. (They are like new) A Focus on doors thicker than the scorpion like - so have to get up! Deon January 30, 2008 - 23:43 # 2 I put lanterns in the door and connected, each door separately! By highlighting a contact in the mirror okolodvernogo space, as some have suggested formuchane in this thread, I originally did not want to connect. Do not want to be when you open one door included six torches to the other closed! So I began searching for possible inclusion lanterns each door separately. How did you manage to find an experimental way with the almost complete dismantling of one door, a signal for opening the doors to the assembly of the door Ghia is not for no CAN-bus, as in the usual form of analog, 12-volt "minus." But only this "minus" a little bit tricky. He appears on the wire when the door is closed and when opening is disabled. That is, all the way around, the door is closed - "minus" is, is open - "minus" no. Therefore, the need for connecting lanterns to solve the problem, how to activate lights when power is off. The first thing that comes to mind is to put pyatikontaktnoe relay. But this idea is not very suitable, since the closed-door four-winding (each door), the relay will consume current, and discharge the battery. The second connection option - setting the buttons in the front-door switch, but this idea is also not the best. Drilling Fedya, somehow it did not want, and dragging wires from limit switches on the doors is not very pleasant procedure, with a corresponding removal of the front doors. So I decided to try to implement the third option to connect using an existing signal at the door, but without the use of motor pyatikontaktnogo relay. At the forum I was advised to connect radioelektronschikov bulb with a simple shemki built on field-effect transistor. So I did. To connect to the three took podklyuchtitsya provdam at the door (the door opening signal, the "plus" and "minus"). All these wires are already there in the doorway and additional stretch is needed. Colors of the wires in the door, which is a signal of opening: Front left - yellow-black Front right - blue-black The rear and left and right - orange and black Friends, I hope you understand that the above principle of operation signals the opening of doors and colors of the wires - this is not an instruction how to connect the lamps in the door any TRICKS complete Ghia, but the story of how I attached them to his car (07.2007, the a.). On other machines complete Ghia colors of the wires and the principle of the door opening signal, most likely the same, but there may be others! All must be checked! Torches punched in the Shell doors. But not just by setting them outside and drowned inside the casing (spied on a neighbor, as these lamps are in the Audi from the factory). To do this, do the holes in the casing to form the outer part of the flashlight, and the inside of the glued area, cut from plastic casing in the form of a flashlight. And it happened that the body of the flashlight is inserted in the casing is not, and in the playground, pasted under it, and the outer part is flush with the surface of the Shell, without speaking of it. Foty below: Attached Image Deon January 30, 2008 - 23:56 #0 Here foty site on which the lantern: Attached Image sanekk January 30, 2008 - 23:58 #0 Deon Cleve, I already thought of this year, the head is worn on this setup ... More information can be on the connectors, of which he took the signals? Of the connectors on the modules? Or on the locks? And shemku describe in more detail it would not hurt ... Deon January 30, 2008 - 23:58 #0 Ischo Attached Image Deon January 30, 2008 - 23:59 #0 and ischo Attached Image Deon January 31, 2008 - 0:06 #A To the light from the light bulbs did not shine from all the cracks of doors skins, each with a flashlight inside the casings casing made from a plastic beaker for pens. The inside of the hulls painted stationery fonarkov stroke. White hull has significantly increased the brightness of torches, especially whites. Attached Image Deon January 31, 2008 - 0:08 #8 Of course a lot of fuss, but the result is worth it. Even turned off, lanterns look in his place, in the factory. Well, look at all included awesome! When you open the door in the dark, fine white lanterns illuminate the road surface near the car and see where to attack, getting out of the car, and the red bright lights are clearly visible from far away to other drivers! Attached Image Deon January 31, 2008 - 0:08 #7 Ischo phot Attached Image Deon January 31, 2008 - 0:23 #0 sanekk The wire to the signal comes from opening the doors of the castle and goes out the door to the salon directly, bypassing the door module. Since the lock up is not very easy to reach - it is necessary to remove the panel from the window, I simply connected to the wire in the most convenient location. sanekk January 31, 2008 - 0:25 # Deon With your permission, let me finish the wires, which is a signal the opening of the door, and just to correct you. Front left - four contacts on the connector lock a black and yellow Front right - 4 contacts on the connector lock a black and blue Rear doors - 4 contacts on the connector lock a black and orange All these wires go to the GEM module out the door without hitting the door modules in the analog signal. Even on the bus CAN GEM includes posvetku and sends a signal to open the door. What is the connection - see image A bit ahead of me ...And yet, pliz write, with pictures, that the scheme did you use? Where they took the other two signals? I can not understand the schemes more ... # Last updated: January 31, 2008 - 0:30 Attached Image Manu January 31, 2008 - 0:28 #0 Deon class! 5 +! Deon January 31, 2008 - 0:34 #0 sanekk That's right! But I take the signals from the wires before they reach the GEM module, since connected directly to the door. So, what's next with these Segal makes GEM module to work my light has no effect. Shemku lay sha! sanekk January 31, 2008 - 0:36 #A Deon I understand perfectly, this was a retreat as it were, to say this, that the wires do not go to the modules ... All the same, which powered the rest? Where from? The land is clear, with 18 contacts on the module door, the black wire. By the way, with 16 contacts the door module signal goes to the castle, and then out of it is spent on GEM, there is an idea to cling to the module, it's easier, and at break of the chain in the lock, the signal is lost as a wire to the castle, and on the wire after (to which the neck connected). The main thing is not to be confused black-and-yellow and yellow-black. Value of a different color. The first - black with a yellow stripe and the other yellow with black stripe. On the other - by analogy. Deon January 31, 2008 - 0:54 #2 Here shemki lights turn off when the door of "minus" to lock the door. Used to restrict a field effect transistor and the constant resistance IRFZ44N 10k power 0.25W The signal from the lock at the "gate" taranzistora, and the "plus" and "minus" is in each door. Orange with white stripe - a "plus", and black, respectively, the "minus". They both fit in the slots of door modules (number pad, unfortunately I do not remember, but I have no scheme). But they are easy to find the color and they are two very thick. Attached Image Deon January 31, 2008 - 1:53 #9 The boards did not do any. Circuits soldered together and priapayal wires to them. Got this thing. Then he shoved all-in shrink. If a man have any questions, you are welcome! Attached Image -Forester-January 31, 2008 - 2:24 #0 Deon MegaZachOt! new theme for those who have "itching" Posted at 02:28 ** PS while the red lanterns there are some code or reference, well, or as a short seller to explain what I want? Deon January 31, 2008 - 2:46 #2 Finis-codes: Red lanterns VAGovskie: 8D0947411 There are more such VAGovskie, but white: 3B0947415B I put white lights on the Ford hatchback trunk: 6136623 dimka1 January 31, 2008 - 9:18 #0 Deon MegaZachOt! Boom to do. The only downside, if the lamp blows, the transistor, the resistance - to replace the need to remove the door trim, is not good! (Prompt: - and to set the ceiling outside the place enough - strike sharply on the thresholds would not be?) sanekk January 31, 2008 - 9:36 #0 Deon And which of the wires connecting light on the pictures, what is the earth, from what is 12B? I look at my chart and I can not understand what the picture is that ... You can paint the flowers? What color is the wire to the signal door? What kind of advantage? What with the land? As far as I could figure out the scheme, and a picture, black - ground to the door. Green - the signal from the lock. Orange - 12 V through a resistance, there is a positive lead to the bulb. White - the land, stretching from the transistor to the bulb. Home forumaPoiskAvtomobili - Ford Focus ---- FF1 Extras. Equipment and Parts - Ford Focus 2 ---- FF2 Operation ---- FF2 Accessoires and Parts - Ford Focus 3 ---- Engine ---- Chassis ---- Brakes ---- Body and Salon ---- Electrical ---- Optics ---- Wheels ---- Audio, multimedia, navigation and safety systems ---- help ---- Protection Systems ---- Feedback - Ford Focus ST - Ford C-MAX - Ford S-MAX and Galaxy 2006 - Ford Mondeo - 4x4 ---- Ford Escape and Maverick ---- Ford Kuga - Ford Fiesta, Fusion - Commercial vehicles - Diesel engines - Dealers, Services, FMC - Parts and Services WE - Introductions - Around and Inside - Avtobesedka - Archangel Club ---- ---- Novgorod, Vladimir ---- ---- ---- Ekaterinburg Kazan, Ivanovo ---- ---- Kaluga - - Kirov Kostroma ---- ---- ---- Krasnodar Krasnoyarsk Kuzbass ---- ---- ---- Magnitogorsk Moscow Murmansk ---- ---- ---- Nizhny Novgorod Novosibirsk - --- Omsk - Archive ---- ---- Perm Pskov ---- Republic of Karelia, Komi Republic ---- ---- ---- Republic of Mordovia, Rostov-on-Don, Ryazan ---- - - Samara ---- St. Petersburg ---- ---- Saratov Sergiev Posad, Dimitrov ---- ---- Stavropol Tver Tomsk ---- ---- ---- Tula Tyumen - - Ufa ---- Chelyabinsk Cherepovets ---- ---- ---- Black Earth Ugra ---- Yaroslavl ---- Belarus ---- Ukraine ---- FF Racing Club - Archive - Sport - Travel - Hobbies - For Sale ---- Marketplace - For Sale ---- Wheels - Car Audio ---- For Sale - Car - For Sale ---- Sale - Wheels ---- For Sale - Car Audio ---- Sale - Cars Others Topics - News - ffclub.ru - Website Up Write: Related Topics: FF2 Accessoires and Parts - Replacement of rear lights in a wagon with restayla on doreystal and back, FF2 Accessoires and Parts - Guide to Alternative optics FF2 Accessoires and Parts - Rear Optic LED IN.PRO FF2 Accessoires and Parts - Installation of rear diode lights on HB FF2 Accessoires and parts - rear LED lights on the sedan FF2 Accessoires and Parts - Lights handle PPC FF2 Accessoires and Parts - Rear optics In.pro. - Turning blinking FF2 Accessoires and parts - Tinted optics FF2 Accessoires and parts - report on installing lights the door handles FF2 Accessoires and Parts - The second reversing lights, better lighting sx FF2 Accessoires and parts - lighting devices peresvetka FF2 Accessoires and Parts - Alternative optics (v2.0) FF2 Accessoires and Parts - Alternative optics Ford C-MAX - C-MAX 2: optics: rear lights FF1 Extras. Quote Link to comment Share on other sites More sharing options...
Preee Posted February 16, 2012 Author Share Posted February 16, 2012 It sounds as if they are putting White puddle lights on the bottom , red lights to the side of the door , so when the door is open in the dark it will show a red light so any one approaching fromthe rear will see the red light , you get these on alot of hight end cars Quote Link to comment Share on other sites More sharing options...
jane_b Posted February 17, 2012 Share Posted February 17, 2012 yess preee it is like audi and bmw benz ... i just didnt know how they where instaling the lights i undestand everything exept the wirring part from which conection r they taking the power for every door seperatly.by the way i just like the look and is also safety when you open the door:D:D:D Quote Link to comment Share on other sites More sharing options...
Bigdaddycain Posted February 17, 2012 Share Posted February 17, 2012 I found that russian translation quite an entertaining "little" read! Very amusing, though i'm not certain whether it's a good, or bad thing that i got the gist of most of it! Great write up Pree! After reading up on all the LED "how to's" on here this evening, i've decided to take the plunge, and order all the bits & bobs to illuminate the: Front and rear door handles (blue),puddle light each door (white SMD strip), Maybe use a 3SMD strip on each door jamb as a door open warning light (red) And a couple on the leading edge of the tailgate (3 SMD strips) as a warning that the tailgate is open... I've noticed on some forum members interior images that there is a door below the heater controls covering up the cubby where the cig socket is, There's no "door" on mine, nor does there appear to be a method of attaching one... I was thinking of fitting an LED in there too, just to get the aperture glowing... If i did that little lot, then i'd HAVE to get my a**e in gear and sort out blue illumination for the complete dash and all the switches... Gawd knows how i'd get my Sony/ford double DIN head unit to light up blue though! Quote Link to comment Share on other sites More sharing options...
Preee Posted February 17, 2012 Author Share Posted February 17, 2012 Bigdaddy. JohnH has a great guide on how to change the LED's on the radio , his link is in his signature. the red safety feature for the door open is a good idea i think , i have some spare low glow red Led strips i could use and may have a look at fitting them , only have 2 though. i like the idea of puddle lights but only if they were fitted to the mirror's , but fot me not using the remote key to open my car then i would be already stood in the puddle as i pulled the door handle so the puddle lights are not for me :) Quote Link to comment Share on other sites More sharing options...
PaulB1803 Posted February 25, 2012 Share Posted February 25, 2012 A couple of pics of mine that i did a while back. Quote Link to comment Share on other sites More sharing options...
Preee Posted February 26, 2012 Author Share Posted February 26, 2012 Looks good Paul , did you do the rears as well? Quote Link to comment Share on other sites More sharing options...
Bigdaddycain Posted February 27, 2012 Share Posted February 27, 2012 Bigdaddy. JohnH has a great guide on how to change the LED's on the radio , his link is in his signature. the red safety feature for the door open is a good idea i think , i have some spare low glow red Led strips i could use and may have a look at fitting them , only have 2 though. i like the idea of puddle lights but only if they were fitted to the mirror's , but fot me not using the remote key to open my car then i would be already stood in the puddle as i pulled the door handle so the puddle lights are not for me :) Cheers Paul ;) Quote Link to comment Share on other sites More sharing options...
Bigdaddycain Posted February 27, 2012 Share Posted February 27, 2012 A couple of pics of mine that i did a while back. Love it! Quote Link to comment Share on other sites More sharing options...
PaulB1803 Posted February 28, 2012 Share Posted February 28, 2012 Looks good Paul , did you do the rears as well? Yeah, but forgot to take some pics of them lol. Quote Link to comment Share on other sites More sharing options...
ijustwantafile Posted March 27, 2012 Share Posted March 27, 2012 how come you have to take the door panel off? are you not just using the power that is already on the switches? I might have a look into doing this at the weekend but don't have a drill with me so was thinking is there room to have a light come through on the gap around the plastic cover where the handle goes through... Quote Link to comment Share on other sites More sharing options...
Preee Posted March 27, 2012 Author Share Posted March 27, 2012 how come you have to take the door panel off? are you not just using the power that is already on the switches? I might have a look into doing this at the weekend but don't have a drill with me so was thinking is there room to have a light come through on the gap around the plastic cover where the handle goes through... it's possible i guess but how would you secure the LED , and you would not want the door handle rubbbing against the wires or LED Quote Link to comment Share on other sites More sharing options...
ijustwantafile Posted March 31, 2012 Share Posted March 31, 2012 it's possible i guess but how would you secure the LED , and you would not want the door handle rubbbing against the wires or LED I fitted it earlier, this is what I manged to come up with: I'm waiting for it to go dark and I'll see how much light it show around the handle. Also I'm still not sure why you have put in the guide to take off the door panel. I just popped the cover off and wired it up and put it back in. I also noticed the light stays on for around 5sec then shuts off, at first I thought it wasn't going to turn off and I had wired it up wrong. Quote Link to comment Share on other sites More sharing options...
Preee Posted March 31, 2012 Author Share Posted March 31, 2012 Also I'm still not sure why you have put in the guide to take off the door panel. Quite simply , my N/S wires were short so i took the panel off and it also serve's for if someone wants to take a panel off. As it states ,it's a Guide people can choose the way they want to do it. Quote Link to comment Share on other sites More sharing options...
clubber Posted September 11, 2012 Share Posted September 11, 2012 Ordered my LED's last night. Will be fitting these when I receive them. Another top guide Preee Quote Link to comment Share on other sites More sharing options...
clubber Posted September 22, 2012 Share Posted September 22, 2012 LED's arrived today, fitted them to all 4 doors. Didn't bother taking door cards off. Just stick the wires into the existing plug and taped it up. Looks good and a worthwhile and easy mod. Can't wait for it to get dark! Quote Link to comment Share on other sites More sharing options...
Preee Posted September 22, 2012 Author Share Posted September 22, 2012 LED's arrived today, fitted them to all 4 doors. Didn't bother taking door cards off. Just stick the wires into the existing plug and taped it up. Looks good and a worthwhile and easy mod. Can't wait for it to get dark! You will love the effect Clubber , i fitted some to my Nephews ST (facelift) the other weekend and the wiring was totally different , but got it working so it comes on with Ignition. looks great though he choose green Led's also did his cupholders so a nice tint of green inside the ST. Quote Link to comment Share on other sites More sharing options...
clubber Posted September 22, 2012 Share Posted September 22, 2012 You will love the effect Clubber , i fitted some to my Nephews ST (facelift) the other weekend and the wiring was totally different , but got it working so it comes on with Ignition. looks great though he choose green Led's also did his cupholders so a nice tint of green inside the ST. The wiring in my ST facelift was exactly the same as yours apart from the back that were a slightly different colour combination. Quote Link to comment Share on other sites More sharing options...
Preee Posted September 22, 2012 Author Share Posted September 22, 2012 Nephews is a two door , all all the wiring for the passenger door were, the electric window one shot up/down without ignition there was no power there at all even with the lights on.Thats why his only come on with ignition , seems wiring is different on a few Focus's Quote Link to comment Share on other sites More sharing options...
SkinnyB Posted October 27, 2012 Share Posted October 27, 2012 Got mine in the post today :) very excited bout this little mod. I'm doing all my interior red (well red lights/led) so this will be a nice little touch. One question I have though I have a set of logo lights/ puddle lights, I'm not very good with a multimeter but I tried to find wires to connect them to so that they turn on when I open the door but there doesn't seem to be any wiring for this in my door. Anyone know how I can connect these little buggers? Looking to do a guide on it if I can find out how or where to connect the wires. Quote Link to comment Share on other sites More sharing options...
Preee Posted October 27, 2012 Author Share Posted October 27, 2012 Where do you plan on fitting the Logo lights in the mirror's or bottom of the door? You could run a wire from the interior light through the door rubber grommet , so they will come on when you open the door. If your fitting in the mirror then maybe you could get the power from the door lock , but not sure on that. Quote Link to comment Share on other sites More sharing options...
SkinnyB Posted October 27, 2012 Share Posted October 27, 2012 Where do you plan on fitting the Logo lights in the mirror's or bottom of the door? You could run a wire from the interior light through the door rubber grommet , so they will come on when you open the door. If your fitting in the mirror then maybe you could get the power from the door lock , but not sure on that. Quote Link to comment Share on other sites More sharing options...
SkinnyB Posted October 27, 2012 Share Posted October 27, 2012 I've already fitted them to the bottom of the door panel. As for running the wire from the interior light that's just a no go as I can't even get the metal panel off (which I believe is attached to the window or the window mechanism) behind the door card. There are 5 black wires running to the door lock I believe, I might just try that tommorow, looks like its back out with the multimeter for me. Will update tomorrow. Cheers Preee! Quote Link to comment Share on other sites More sharing options...
SkinnyB Posted October 29, 2012 Share Posted October 29, 2012 Just a quick update, managed to connect the logo lights to the door lock, there is 5 black wires running to the door lock. 3 thick ones and 2 thin ones, connected ground to one of the thick ones and positive to one of the thin ones (having the multimeter at hand did help). Only thing in not that happy about is the logo lights themself Quote Link to comment Share on other sites More sharing options...
