FocusGhia16V Posted March 12, 2012 Share Posted March 12, 2012 Hi there. About to do my first cambelt change on a Focus 1.6 Zetec SE. Job looks ok but just wondering if anyone had any tips on pressing on the crankshaft pulley as its a taper & interferance pulley. Thanks Quote Link to comment Share on other sites More sharing options...
stef123 Posted March 12, 2012 Share Posted March 12, 2012 should be able to tap it on no problem. have you got the proper locking kit? Quote Link to comment Share on other sites More sharing options...
FocusGhia16V Posted March 29, 2012 Author Share Posted March 29, 2012 Yep got the correct locking kit and also a flywheel lock to make sure timing doesnt move whilst changing belt. Also managed to find a tool to re-press the crank pulley back on before doing the pulley bolt up. Quote Link to comment Share on other sites More sharing options...
fordtech Posted March 27, 2014 Share Posted March 27, 2014 Just make sure you torque the pulley bolt up correctly. Sent from my iPad using Ford OC Quote Link to comment Share on other sites More sharing options...
shaunytee1600 Posted August 31, 2014 Share Posted August 31, 2014 Don't forget to manually turn the engine over via the crank pulley to make sure belt is seated and ensuring engine doesn't lock up before you turn engine over via the ignition. Power is nothing without control . Quote Link to comment Share on other sites More sharing options...
