lpoolm Posted October 24, 2012 Share Posted October 24, 2012 Hi, I have a focus diesel 56 plate. Can anyone tell me how to turn engine management light off other than taking to a garage. Long story short had a faulty sensor which I have changed now car runs fine but still has engine management light on as needs resetting! I have read unplugging battery can do it (tried for 10 mins but light still on). Or is there a fuse for the engine management light, I do not have a manual to check fuses unfortuantly. Any advice would be great thanks. Quote Link to comment Share on other sites More sharing options...
Mike77 Posted October 24, 2012 Share Posted October 24, 2012 Needs plugging in basically mate, to erase the code, not much else you can do afraid Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted October 25, 2012 Share Posted October 25, 2012 I believe there's a sequence involving the pedals when turning the ignition on but not starting the car. Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted October 25, 2012 Share Posted October 25, 2012 Found it. Try this and see how you go. 1. Close all doors. 2. Turn the ignition key to position II. 3. Simultaneously press the accelerator pedal and the brake pedal and hold for a minimum of 15 seconds. 4. The oil change reminder indicator will turn off. This confirms that the reset procedure has been correctly completed. Quote Link to comment Share on other sites More sharing options...
ferretfloozy Posted October 25, 2012 Share Posted October 25, 2012 try driving around for at leat 30 mins so it completes a full check then park up (engine stopped) for 5 mins worked on my fiesta before i bought a reset/reader Quote Link to comment Share on other sites More sharing options...
STEADS Posted October 25, 2012 Share Posted October 25, 2012 where about in cheshire are you got a scanner that willl turn it out bfor you if your n ear by Quote Link to comment Share on other sites More sharing options...
lpoolm Posted October 25, 2012 Author Share Posted October 25, 2012 Thanks for the replies, going to give the pedal pressing a go in a few minutes, will update if it works!.. or if it doesn't! (I am in St Helen's by the way) Quote Link to comment Share on other sites More sharing options...
STEADS Posted October 25, 2012 Share Posted October 25, 2012 if you coming down ellesmere port/chester way in the near future give us a shout pm me and i.ll sort it for you . Quote Link to comment Share on other sites More sharing options...
lpoolm Posted October 25, 2012 Author Share Posted October 25, 2012 if you coming down ellesmere port/chester way in the near future give us a shout pm me and i.ll sort it for you . Thanks for the offer mate, I work at Cheshire oaks so always down that way! Anyway I tried unplugging the battery - does not work Also the pedal thing, did not work either. Anyway I was very lucky to have a friendly local garage that turned the light off with no charge so very happy now! Thanks for all the input and advice, I do like this forum, lots of helpful people! Quote Link to comment Share on other sites More sharing options...
STEADS Posted October 25, 2012 Share Posted October 25, 2012 no probs if it comes on again give us a shout the oaks is right on my door step 2 mins away Quote Link to comment Share on other sites More sharing options...
Dougeydoogle Posted April 22, 2023 Share Posted April 22, 2023 On 10/25/2012 at 1:56 AM, Stoney871 said: Found it. Try this and see how you go. 1. Close all doors. 2. Turn the ignition key to position II. 3. Simultaneously press the accelerator pedal and the brake pedal and hold for a minimum of 15 seconds. 4. The oil change reminder indicator will turn off. This confirms that the reset procedure has been correctly completed. All so worked on a 2028 Ford Connect Tourneo. Thank you. Quote Link to comment Share on other sites More sharing options...
unofix Posted April 22, 2023 Share Posted April 22, 2023 On 4/22/2023 at 4:36 PM, Dougeydoogle said: All so worked on a 2028 Ford Connect Tourneo. Thank you. Also works on a DeLorean in聽 back to the future 馃ぃ 聽 Quote Link to comment Share on other sites More sharing options...
