MrsMcBee Posted December 28, 2012 Share Posted December 28, 2012 I am hoping someone can help or point me in the right direction please? 59 plate Fiesta Titanium won't start. It's keyless ignition and it unlocks, stereo works but ignition button won't start the car. It flashed up a message once, power steering failure but it had just been driven with no issues then when we went to start it 5 minutes later, it refused to do anything. It's stuck in a parking bay with the steering lock on so we can't move it but we have to get it moved somehow or parking tickets daily! Fuses have been checked and all seem ok. Ford can't even look at it until next Wednesday! Any ideas or suggestions would be appreciated. Quote Link to comment Share on other sites More sharing options...
Lenny Posted December 28, 2012 Share Posted December 28, 2012 I am hoping someone can help or point me in the right direction please? 59 plate Fiesta Titanium won't start. It's keyless ignition and it unlocks, stereo works but ignition button won't start the car. It flashed up a message once, power steering failure but it had just been driven with no issues then when we went to start it 5 minutes later, it refused to do anything. It's stuck in a parking bay with the steering lock on so we can't move it but we have to get it moved somehow or parking tickets daily! Fuses have been checked and all seem ok. Ford can't even look at it until next Wednesday! Any ideas or suggestions would be appreciated. Is their any emergency key for keyless entry? Ive saw Mk7's drive in to work fine but wouldnt start when going home, Common fault with ignition ring sensor not sencing the key chip is inserted, But yours is keyless. If still under warrenty, id pass the parking fee's on to ford because the fault caused the fee's Quote Link to comment Share on other sites More sharing options...
MrsMcBee Posted December 28, 2012 Author Share Posted December 28, 2012 No, it's just out of warranty (October). There is an emergency key inside the fob but it's only to open the doors. There is no ignition barrel to fit a key in that I can see. Quote Link to comment Share on other sites More sharing options...
stef123 Posted December 28, 2012 Share Posted December 28, 2012 Has it got an immobiliser light? What's it doing when you try to start? Quote Link to comment Share on other sites More sharing options...
MrsMcBee Posted December 28, 2012 Author Share Posted December 28, 2012 Yes it has, the factory fitted one. Basically, it does nothing when you press the start button. Radio works, lights work etc but it doesn't start the engine at all. The odd thing is, 5 minutes before it was fine. It was just when we tried to start it to head off for Xmas dinner! Doh! just read that again - I don't think it was flashing but I'll let you know. UPDATE - no flashing. Although my thoughts are it is immobilised somehow! Quote Link to comment Share on other sites More sharing options...
Preee Posted December 29, 2012 Share Posted December 29, 2012 The emergency key that you use to open the door fits in where the usual Ign key would go there is a plastic circle panel that if you use the key clips off , insert the key , foot on clutch and try the start button. The key does not turn it just slides in. Quote Link to comment Share on other sites More sharing options...
MrsMcBee Posted December 29, 2012 Author Share Posted December 29, 2012 Thanks Preee, I knew there was something about the key but couldn't find it in the manual. Had it towed to the Ford dealer this morning but they can't look at it until Wednesday. God knows how much it's going to cost - £60 just for a diagnostic and another £50 for the tow so far. I'll post what the issue was once I know. Thanks all. Quote Link to comment Share on other sites More sharing options...
Preee Posted December 29, 2012 Share Posted December 29, 2012 Your welcome , hope its an easy fix , i had a problem starting my old Focus Mk2.5 once and used the Key to start it and it worked and cleared the fault , Ford then updated the system for me. Quote Link to comment Share on other sites More sharing options...
MrsMcBee Posted January 2, 2013 Author Share Posted January 2, 2013 UPDATE Steering lock failure - £410 to replace! Quote Link to comment Share on other sites More sharing options...
Preee Posted January 2, 2013 Share Posted January 2, 2013 Wow thats a lot of money for a steering lock , i would ask for the broken part back so you can get it checked Quote Link to comment Share on other sites More sharing options...
b1g_dav3 Posted January 2, 2013 Share Posted January 2, 2013 Guessing you're only just out of warranty? >.< Quote Link to comment Share on other sites More sharing options...
MrsMcBee Posted January 3, 2013 Author Share Posted January 3, 2013 Guessing you're only just out of warranty? >.< Yep - by 2 months :( Time to get rid. Quote Link to comment Share on other sites More sharing options...
colin79666 Posted January 3, 2013 Share Posted January 3, 2013 Yep - by 2 months :( Time to get rid. Ask the dealer to approach Ford for a good will contribution. No way that part should fail within the life of e car and especially not < 5 years. Quote Link to comment Share on other sites More sharing options...
