Jayy-mk6 Posted January 20, 2013 Share Posted January 20, 2013 Just bought some clear side indicators, what's the easiest way to remove them and refit? Thanks (mk6 fiesta zetec) Quote Link to comment Share on other sites More sharing options...
DanGersFord Posted January 20, 2013 Share Posted January 20, 2013 Its dead easy, get a very fine flat screwdriver and a towel. Insert the screw driver into the side nearest to the door using the towel so that you dont scratch your paintwork and just pop the indicator out. Its just a small push clip that holds it in, then you need to twist the indicator the remove it from the bulbs holder. Then change the bulb if they send a spare and push and lock the new indicator onto the bulb holder and push the side of the indicator furthest away from the door into place first and clip the other side in :) Quote Link to comment Share on other sites More sharing options...
Jayy-mk6 Posted February 9, 2013 Author Share Posted February 9, 2013 How do I remove and replace the actual bulb? And Is it best to disconnect the battery?... Quote Link to comment Share on other sites More sharing options...
DanGersFord Posted February 9, 2013 Share Posted February 9, 2013 Theres a guide ive made on how to do it. No you dont need to disconnect the battery youbliterally just pull the old bulb out and push the new bulbs in just make sure you use a cloth when handling the new bulb. Because its halogen if you to the bulb with your actual fingers itll make it blow alot quicker Quote Link to comment Share on other sites More sharing options...
