TimWills17 Posted April 10, 2013 Share Posted April 10, 2013 How do I remove door handles. Thinking of spraying them met silver along with gear surround? Quote Link to comment Share on other sites More sharing options...
DanGersFord Posted April 10, 2013 Share Posted April 10, 2013 Inner door handles or outer? Quote Link to comment Share on other sites More sharing options...
TimWills17 Posted April 10, 2013 Author Share Posted April 10, 2013 Both if you know. But I'm planing on the inner for now. But will colour code the outside when weather is better :) Quote Link to comment Share on other sites More sharing options...
DanGersFord Posted April 10, 2013 Share Posted April 10, 2013 Im fitting a set of these soon http://www.fordpartsuk.com/shop/ford_st150_inner_door_handle_set_f_KITFIETRIM1_c_115.htm so ill let you know how they come off when i do it :). Hopefully over the next 2-3weeks. As far as i know its just one screw that holds the inner door handle in Quote Link to comment Share on other sites More sharing options...
TimWills17 Posted April 10, 2013 Author Share Posted April 10, 2013 Oh no not that they have just one screw. I mean the other pull handle that is used to pull door Quote Link to comment Share on other sites More sharing options...
Nathan_M Posted April 10, 2013 Share Posted April 10, 2013 If its the same door panel as mine it looks like you need to take the whole door panel off and then it will be screwed or slotted into the main plastic carcass, Im not sure if that plastic would look that good painted as its textured, have you searched the web in regards to buying colored ones that are made from the relevant plastic color. Quote Link to comment Share on other sites More sharing options...
TimWills17 Posted April 10, 2013 Author Share Posted April 10, 2013 Oh are they a different texture?? Quote Link to comment Share on other sites More sharing options...
TimWills17 Posted April 10, 2013 Author Share Posted April 10, 2013 Any guide on how to take door apart? Quote Link to comment Share on other sites More sharing options...
Nathan_M Posted April 11, 2013 Share Posted April 11, 2013 On mine it has a rough texture, I suppose if you paint it a few times it would comes smooth, and I would say that to remove the panel it's a couple of screws and/or knowing ford many many hundreds of easy to break clips. Quote Link to comment Share on other sites More sharing options...
TimWills17 Posted April 11, 2013 Author Share Posted April 11, 2013 Ill give it a go when I have some patience then lol thanks Quote Link to comment Share on other sites More sharing options...
