Gaz RS Posted June 8, 2013 Share Posted June 8, 2013 Joe, you never said what the model number on your bluetooth unit was? Quote Link to comment Share on other sites More sharing options...
Jojofish99 Posted June 8, 2013 Share Posted June 8, 2013 Its a 8M5T-19G488 Gaz Quote Link to comment Share on other sites More sharing options...
Gaz RS Posted June 8, 2013 Share Posted June 8, 2013 Joe, please download this and read the read me, it mat be that you need to install dll and drivers. It also contains an earlier version of elmconfig Focus ST ELM Config.zip Quote Link to comment Share on other sites More sharing options...
Jojofish99 Posted June 8, 2013 Share Posted June 8, 2013 OK cheers mate, I'll have a go tomorrow and let you know how I get on. Quote Link to comment Share on other sites More sharing options...
philiprbrown Posted June 9, 2013 Author Share Posted June 9, 2013 Gaz/Joe I modded my cable on Friday and tried but experienced the same problem as Joe (wouldn't write to the SRM). I wanted to rule out any 'wiring' problems before raising an issue which I did last night (there were none that I could see). However on seeing the latest posts I have this morning followed the instructions on the download and it I have now updated the SRM successfully. Couple of points though, - I am using a 64 bit o/s and copied the files directly to the directory in the READ ME file. However one of the files would not copy or move (msbvm60.dll). This now appears not to be a problem for the SRM activation. - There was no BT/VC Low option in the SRM config menu. I chose bluetooth & USB. This also appears not to be a problem. - Make sure voice control is ticked in the HEC Configuration Page 1 tab. When tested the SRM appeared to be working fine albeit you follow these tips at your own risk as I now have another more serious problem that I wonder if Gaz can help with. When in the HEC module, I was able to read configuration page 1 & 2 fine. I tried page 3 and it gave some warning dialogues which I saw when playing with the software on Friday that did not cause any problem and allowed me to read the settings. However today when I progressed through the warnings I have now lost all HEC function on the dashboard and the software will not communicate (states no data). Other modules can still be read fine so presuming this is not a wiring issue. I have restarted the software on the PC but no joy. Any help would be appreciated in my panicked state! Phil Quote Link to comment Share on other sites More sharing options...
philiprbrown Posted June 9, 2013 Author Share Posted June 9, 2013 Ok, Having done a bit of panicky research across the forums, the suggestion was to disconnect the battery for 15 mins and hope for a reset - which I duly did. This appears to have cured the issue with the HEC as all appears to be functioning correctly. The SRM module also still works so feeling like a very lucky boy at the moment. In light of my antics this morning my best advice would be to STAY AWAY FROM HEC CONFIGURATION PAGE 3 unless you know what you are doing. Thanks all for your help Phil Quote Link to comment Share on other sites More sharing options...
Jojofish99 Posted June 10, 2013 Share Posted June 10, 2013 Hi Gaz, Well done to Phil, Unfortunately i'm still struggling. I did what you advised, I've got outgoing and incoming calls but still no in car audio. Mic works fine and the voice button shows "voice" on the radio but without any vocal feedback i'm not sure whats going on with the SRM. Please see the attached, i'm getting this whenever I try to write current config to the HEC. Not sure what it means as the info seems to be there? Ive checked the wiring as far as I can see could it be as simple as ascreenshot.pdf plug missing somewhere? Cheers. Joe. Quote Link to comment Share on other sites More sharing options...
philiprbrown Posted June 10, 2013 Author Share Posted June 10, 2013 Joe I presume you have the audio patch lead suggested by Gaz in post #2 of this thread? Having looked at your screenshot, i dont recognise the user interface for the version of the software you are using. Have you used the link provided by Gaz in post #28 as this is the one that I used and which worked. Cheers Phil Quote Link to comment Share on other sites More sharing options...
Jojofish99 Posted June 10, 2013 Share Posted June 10, 2013 Hi Phil, Yes ive done the patch lead and tried the suggested version neither works? Joe Quote Link to comment Share on other sites More sharing options...
Gaz RS Posted June 10, 2013 Share Posted June 10, 2013 Hi Phil/ Joe, sorry I haven't been on here the past couple of days I was at the RS show at Croft on Sunday and got called out to work today :( I'm sorry you had a few problems, I did know about the the HEC problem but didn't expect you to go into that as I never had to. I only needed to look at the SRM. This may have been sorted in the latest version I'm not sure! I'm pleased to read that you managed to sort everything out, just remember that if you intend to alter anything else PLEASE BACK UP USING THE SAVE CONFIGURATION FUNCTION If you want to keep up to date with this software use google translate to read the Russian thread http://ffclub.ru/topic/302511/#comments Joe, the picture suggests your using the wrong software, as I said above I never had to alter anything on the HEC. When you open elmconfig 0.2.5 which is in the download on post #28 did you go into ELM Setup and press Setup ELM327 for MS-CAN bus? When you say you have no audio does this mean no music or just voice and phone audio? Quote Link to comment Share on other sites More sharing options...
Jojofish99 Posted June 11, 2013 Share Posted June 11, 2013 Hi Gaz, I used the incorrect software first and then changed to the ST software when it wouldn't work. I did use the ELM Setup and press Setup ELM327 for MS-CAN bus.The music is fine and cuts out for "calls" just no audio on the voice/ phone. Cheers Quote Link to comment Share on other sites More sharing options...
Gaz RS Posted June 11, 2013 Share Posted June 11, 2013 Joe, I think it could only be that the settings need to be changed , if you try again using version 0.2.5 of elmconfig, change the settings in SRM to the same as in the picture and see if that works. Quote Link to comment Share on other sites More sharing options...
philiprbrown Posted June 11, 2013 Author Share Posted June 11, 2013 When i set up my SRM, i wasnt given the option highlighted above. I instead chose 'bluetooth & USB' i have used this several times today with no problems. Gaz, thanks. The HEC thing was my fault as i got curious. Phil Quote Link to comment Share on other sites More sharing options...
Jojofish99 Posted June 11, 2013 Share Posted June 11, 2013 Hi Gaz Tried that and every other config too. Beginning to wonder if its a dodgy SRM now? Checked the wiring again today and no joy there. Joe. Quote Link to comment Share on other sites More sharing options...
Gaz RS Posted June 11, 2013 Share Posted June 11, 2013 You may be right Joe, one more thing to try. In SRM press on Procedures and then on Reset Module then check the other setting in Configuration, after that I wouldn't know what to suggest :( Quote Link to comment Share on other sites More sharing options...
Gaz RS Posted June 11, 2013 Share Posted June 11, 2013 When i set up my SRM, i wasnt given the option highlighted above. I instead chose 'Bluetooth & USB' i have used this several times today with no problems. Gaz, thanks. The HEC thing was my fault as i got curious. Phil Phil I've looked at the setting in a few versions of elmconfig and non have just " bluetooth & USB " can you confirm what version you used and the exact setting, you can have a look using offline function. This might help Joe. Quote Link to comment Share on other sites More sharing options...
philiprbrown Posted June 12, 2013 Author Share Posted June 12, 2013 Gaz, Sorry you are correct in your above screenshot, this is what I used. Not quite sure where I saw the option I described although in my defence Sunday morning was a bit of a panic when it all looked to be going wrong!! Definitely version 0.2.5 as well Cheers Phil Quote Link to comment Share on other sites More sharing options...
Jojofish99 Posted June 12, 2013 Share Posted June 12, 2013 Hi Gaz/Phil, Unfortunately no joy it looks like a new SRM . Ordered it today should be here by Friday. Watch this space. "I'll be back" Joe. Quote Link to comment Share on other sites More sharing options...
Jojofish99 Posted July 4, 2013 Share Posted July 4, 2013 Hi Phil/Gaz, Sorry for not getting back sooner I've been away for a couple of weeks. I've found the problem! One of the cables on the small white plug on the back of the Head unit was just out of the plug. probably shifted it when I slid the unit out early doors . May be of use to someone if it happens again somewhere? I've got to sus out how the voice commands work now! Thanks again for your help and patience with this. Joe Quote Link to comment Share on other sites More sharing options...
philiprbrown Posted July 4, 2013 Author Share Posted July 4, 2013 joe, Great news. Enjoy Phil Quote Link to comment Share on other sites More sharing options...
Gaz RS Posted July 4, 2013 Share Posted July 4, 2013 Hi Phil/Gaz, Sorry for not getting back sooner I've been away for a couple of weeks. I've found the problem! One of the cables on the small white plug on the back of the Head unit was just out of the plug. probably shifted it when I slid the unit out early doors . May be of use to someone if it happens again somewhere? I've got to sus out how the voice commands work now! Thanks again for your help and patience with this. Joe Thought you'd given up on it Joe, pleased you got there in the end though :) This will help you with voice commands Ford_BVC_GS_A4_EN.pdf Quote Link to comment Share on other sites More sharing options...
Jojofish99 Posted July 4, 2013 Share Posted July 4, 2013 I said "I'll be back". I wasn't giving up easily!! Thanks for the instructions Joe Quote Link to comment Share on other sites More sharing options...
philiprbrown Posted September 13, 2013 Author Share Posted September 13, 2013 I have managed to acquire a 19C112 unit to replace my 19g488, have just installed it and all is working fine including the audio streaming. Only one issue now is the link cable from the old 488 unit usb to the glovebox USB socket is not compatible with the new 112 unit which has a mini usb connector out. Can anyone advise the correct part nr for the mini USB to glovebox USB socket to suit the 19c112 unit? Thanks Phil Quote Link to comment Share on other sites More sharing options...
spiceytitanium Posted October 19, 2013 Share Posted October 19, 2013 I have just finished retrofitting bluetooth into my Titanium 09 Plate i had to use the patch loom as i had no cable after looking for it, everything communicates fine, except i hear no audio during play back, i have searched for the areas of which the mic and audio patches could go as shown on other topics on here, does anyone have any ideas as i'm now stumped and a little annoyed. I do have my aux cable which was connected in glove box still attached to the stereo loom could this be affecting it? Quote Link to comment Share on other sites More sharing options...
spiceytitanium Posted October 19, 2013 Share Posted October 19, 2013 By way of an update I fitted the microphone, and the audio patch lead and the system works fine now. Like Jo, I couldn't find the 'empty' connector for the microphone patch lead but seems this is not needed. Mine is a 2010 Focus with a build date of 22/1/2010. Thanks for your help Gaz Phil I am having problems locating where the Audio patch lead goes, could you please let me know where yours was. Mine is 2009 Focus with a build date of 25/06/09. Thanks Quote Link to comment Share on other sites More sharing options...
