gampla Posted June 29, 2013 Share Posted June 29, 2013 hi has anyone sprayed there calipers and drums as mine are looking a little worst for wear the look new so i was thinking about rubbing them down with a wire brush and spraying anti rust primer followed by top coat not sure on what colour. Quote Link to comment Share on other sites More sharing options...
sambooka Posted June 30, 2013 Share Posted June 30, 2013 Black any other colour will just show how small they are or look dirty all the time Quote Link to comment Share on other sites More sharing options...
b1g_dav3 Posted June 30, 2013 Share Posted June 30, 2013 Silver also isn't too bad on calipers, even when dirty they don't look like they were painted really. Quote Link to comment Share on other sites More sharing options...
Gary Minty Jupe Posted June 30, 2013 Share Posted June 30, 2013 done my drums and calipers with a metallic silver high temp paint (no need for primer) Quote Link to comment Share on other sites More sharing options...
Marcr1 Posted June 30, 2013 Share Posted June 30, 2013 ^ Looks good :D Quote Link to comment Share on other sites More sharing options...
gampla Posted July 1, 2013 Author Share Posted July 1, 2013 ^ Looks good :D if you want to boost your power look at puma speed there a specialist to fords only Quote Link to comment Share on other sites More sharing options...
gampla Posted July 1, 2013 Author Share Posted July 1, 2013 photo (5).JPGdone my drums and calipers with a metallic silver high temp paint (no need for primer) what paint did you use as i want to put some anti rust on them to keep them rust free a little longer Quote Link to comment Share on other sites More sharing options...
b1g_dav3 Posted July 1, 2013 Share Posted July 1, 2013 I just use Hammerite paint with a brush on callipers, can stand heat and it's rust proofing, both painted before or after rust has got in. Quote Link to comment Share on other sites More sharing options...
Lester1102 Posted July 1, 2013 Share Posted July 1, 2013 I just painted my calipers in a light blue I will post picks tomorrow Quote Link to comment Share on other sites More sharing options...
Lester1102 Posted July 2, 2013 Share Posted July 2, 2013 I said I would post s pic of my blue callipers when I had chance Quote Link to comment Share on other sites More sharing options...
gampla Posted July 3, 2013 Author Share Posted July 3, 2013 which give better look painted or sprayed? Quote Link to comment Share on other sites More sharing options...
Lester1102 Posted July 4, 2013 Share Posted July 4, 2013 If u can take them off and don't mind the wait then I would get then powder coated but if its a choice between brush paint or aerosol paint I would choose brush purely because u have to mask off loads with the can because of the amount of area it covers and also you are less likely to get runs with a brush and a can would take loads if layers because the cast tht the callipers ate made out of will just absorb the paint and you don't have to worry about brush marks because if u get calliper paint then it is self levelling and will smooth itself out Quote Link to comment Share on other sites More sharing options...
gampla Posted July 4, 2013 Author Share Posted July 4, 2013 If u can take them off and don't mind the wait then I would get then powder coated but if its a choice between brush paint or aerosol paint I would choose brush purely because u have to mask off loads with the can because of the amount of area it covers and also you are less likely to get runs with a brush and a can would take loads if layers because the cast tht the callipers ate made out of will just absorb the paint and you don't have to worry about brush marks because if u get calliper paint then it is self levelling and will smooth itself out i was going to get http://www.ebay.co.uk/itm/E-Tech-Brake-Caliper-Paint-Kit-Engine-Bay-Brakes-Manifold-ETECH-Drum-Metal-Car-/280943885574?pt=UK_DIY_Material_Paint_Varnish_MJ&var=&hash=item41698f7d06 or http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_222643_langId_-1_categoryId_255239 Quote Link to comment Share on other sites More sharing options...
stevegtuk Posted July 4, 2013 Share Posted July 4, 2013 I used hammerite on mine, its just a matter of where you can get it the cheapest. Quote Link to comment Share on other sites More sharing options...
trikidy Posted July 5, 2013 Share Posted July 5, 2013 I'll be doing mine soon Quote Link to comment Share on other sites More sharing options...
Lester1102 Posted July 5, 2013 Share Posted July 5, 2013 I did mine as soon as I got it just to stop them rusting they should look better against a black alloy Quote Link to comment Share on other sites More sharing options...
trikidy Posted July 5, 2013 Share Posted July 5, 2013 I was debating this hammerite http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=300481667088&ssPageName=ADME:X:RTQ:GB:1123 or this http://www.ebay.co.uk/itm/270908604320?var=570058026879&ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649 Went for the second as I messaged the first and they said it was not heat resistant like the second one is, he said it would probably be okay but I'd rather have the one that says it Quote Link to comment Share on other sites More sharing options...
Lester1102 Posted July 5, 2013 Share Posted July 5, 2013 The Hammerstein one would have been alright because tht is what Halfords website have in there calliper and drum paint section I went to Halfords and bought there Halfords brand calliper paint which cost a tenner but the hammerite blue wasn't the shade of blue I wanted. I then decided to paint them whilst hungover from a weekend in Manchester to think tht I didn't use a lot of paint so a tenner was a bargain then I stood up and kicked the paint over :( now my driveway is blue ha Quote Link to comment Share on other sites More sharing options...
Lester1102 Posted July 5, 2013 Share Posted July 5, 2013 I did say hammerite but iPhone try's to screw u over with predictive text Quote Link to comment Share on other sites More sharing options...
trikidy Posted July 5, 2013 Share Posted July 5, 2013 haha hammerstein... Yeah I thought it would but I messaged the seller and said its not high temp, kinda put me off! The other stuff is here, just waiting for my mate to bring over a few jacks to do them Quote Link to comment Share on other sites More sharing options...
Lester1102 Posted July 5, 2013 Share Posted July 5, 2013 That's smarter than me I only had one jack and could only do one wheel at a time took me 4 and a half hours better make them jacks with coke ha Quote Link to comment Share on other sites More sharing options...
trikidy Posted July 5, 2013 Share Posted July 5, 2013 ha yeah I am going to do my calipers first, then maybe do my drums in black, depends how the painting goes! Quote Link to comment Share on other sites More sharing options...
Lester1102 Posted July 5, 2013 Share Posted July 5, 2013 What colour are u doing your calipers Quote Link to comment Share on other sites More sharing options...
trikidy Posted July 5, 2013 Share Posted July 5, 2013 Flame red gloss! Quote Link to comment Share on other sites More sharing options...
