pte-ernie Posted April 10, 2014 Share Posted April 10, 2014 Good morning, I have the eml light on in my 2005 mk2 focus titanium. It comes up with the error code p2566 which according to http://www.fordobdcode.com/p2566-ford is: P2566 Turbocharger Boost Control Position Sensor Circuit Intermittent. Can anybody advise if it's the boost control solenoid as the main stealer have said? Really lost and worried it's going to be an expensive fix. Many thanks Quote Link to comment Share on other sites More sharing options...
Christianiani Posted April 10, 2014 Share Posted April 10, 2014 Hi there Rob. Do you have the Reg number of the car because I work at a Motor Factors and have had a quick look and the fault code seem to be suggesting a Boost Pressure Sensor. We do a Bosch version, Part number 0261230119, at about £100 + Vat. Would like a Reg to confirm this though, Thanks, Chris. Quote Link to comment Share on other sites More sharing options...
pte-ernie Posted April 16, 2014 Author Share Posted April 16, 2014 Hi mate same day you posted this I was suggested the same went to unipart and got the same item. Fitted yesterday (literally the only time I've had) and cleared the error codes only for it to come up with the same p2566 again. Noticed some turbo lag too (although that maybe normal and I've not noticed it before) Thank you Rob Quote Link to comment Share on other sites More sharing options...
pte-ernie Posted April 24, 2014 Author Share Posted April 24, 2014 Any help on this greatly appreciated Quote Link to comment Share on other sites More sharing options...
col4519 Posted May 21, 2016 Share Posted May 21, 2016 hi can any one help, i am new here and i have a mk4 58 plate mondeo titanium x 2.0 tdci, i recently acquired a boost up hill problem, would not go above 3000 rev i have had the turbo actuator looked at and it seems to work fine, i have changed the sensors in the front throttle body , changed the throttle body, changed the solenoid at right hand side of engine block... 10 minutes ago Quote Link to comment Share on other sites More sharing options...
trailertrash Posted May 21, 2016 Share Posted May 21, 2016 Hi Colin and welcome. Unfortunately you have chosen the wrong forum, this is the Focus forum. For the Mondeo go to http://www.fordownersclub.com/forums/forum/13-ford-mondeo-vignale-club/ You might also like to try talkford.com, another Ford forum with a far more active Mondeo section. Use a short descriptive title such as "Uphill boost problem 58 plate mk4 Mondeo" or similar. For future reference it is always best to start a new thread with your problem, your query is likely to get missed if you tag it onto an old thread which in this case isn't about a similar problem, or even car. Sorry I can't help with your problem. Good luck! Quote Link to comment Share on other sites More sharing options...
