iant955 Posted May 7, 2014 Share Posted May 7, 2014 Hi Guys, I have an 09 SMax and have recently restored a box trailer and fitted it with LED lights. When I indicate, the indicators flash too quickly indicating a fault with the indicators. I believe this is due to the low draw of the LED indicators and a fault common on some Fords and Landys. I have seen some options which should fix the problem, but nobody seems to know anything about them. I am looking to mount a cure inside the trailer, but the one I have come across most (a basic resistor) gets to 170 degrees C. I ave also come across some other options, but wouldlike some more info on them. Smartbox | LED Lighting | Lights, Reflectors & Electrical | Trailer Parts | Indespension http://www.ledautolamps-uk.com/en/products/i-ls-microprocessor Has anyone had the same problem and if so, how did you get over it? Thanks in advance. Ian Quote Link to comment Share on other sites More sharing options...
