thebaldone Posted April 4, 2008 Share Posted April 4, 2008 Son has just bought a P reg Galaxy and although most things are fine, the central locking will only operate the drivers door? When you turn the key, you can hear the motor in the drivers side rear door but nothing happens. No motor noise from the passenger side at all? Any clues as to where to start please? Quote Link to comment Share on other sites More sharing options...
Steve Posted April 4, 2008 Share Posted April 4, 2008 I dont know the answer to this but are you sure this is not a security feature? does it work if you double press the unlock button on the fob? Quote Link to comment Share on other sites More sharing options...
thebaldone Posted April 4, 2008 Author Share Posted April 4, 2008 I dont know the answer to this but are you sure this is not a security feature? does it work if you double press the unlock button on the fob? No fob that's also part of the problem! Only given a single key when he bought it. Hence other post ref remote. Quote Link to comment Share on other sites More sharing options...
Steve Posted April 4, 2008 Share Posted April 4, 2008 hmm.. is it a valet key? Can it open boot and glovebox? Quote Link to comment Share on other sites More sharing options...
thebaldone Posted April 4, 2008 Author Share Posted April 4, 2008 hmm.. is it a valet key?Can it open boot and glovebox? Will check tomorrow but deffo opens the boot. Quote Link to comment Share on other sites More sharing options...
Steve Posted April 4, 2008 Share Posted April 4, 2008 probably is the main key but check the glove box anyway. have you also tried unlocking the passenger side with the key? Quote Link to comment Share on other sites More sharing options...
thebaldone Posted April 5, 2008 Author Share Posted April 5, 2008 probably is the main key but check the glove box anyway.have you also tried unlocking the passenger side with the key? Just tried the key he has and it locks/opens everything including the glove box. I can hear the motors go in the offside passenger door and the boot but nothing on the nearside doors at all? Looks like there is only a single fuse for all of it though? Drivers door locks fine but I assume that's the actual key doing that rather than central locking motor? I'm going to take the door card off tomorrow on the offside passenger door and have a look at what's actually moving (or not) when the locks activate. Quote Link to comment Share on other sites More sharing options...
thebaldone Posted April 6, 2008 Author Share Posted April 6, 2008 Just tried the key he has and it locks/opens everything including the glove box. I can hear the motors go in the offside passenger door and the boot but nothing on the nearside doors at all? Looks likethere is only a single fuse for all of it though? Drivers door locks fine but I assume that's the actual key doing that rather than central locking motor? I'm going to take the door card off tomorrow on the offside passenger door and have a look at what's actually moving (or not) when the locks activate. On closer inspection, it looks like some clever person has removed the ECU from under the passenger seat! Connectors/cables are there but no black box ! Quote Link to comment Share on other sites More sharing options...
Steve Posted April 6, 2008 Share Posted April 6, 2008 you might find one at the scrappy. Perhaps the old one was faulty and did not lock the car properly. Quote Link to comment Share on other sites More sharing options...
thebaldone Posted April 7, 2008 Author Share Posted April 7, 2008 you might find one at the scrappy. Perhaps the old one was faulty and did not lock the car properly. Gonna try that but the local ones reckon Gal spares are very hard to come by! Looking at the state of the plugs, it looks like the whole area got a dorwning at some time!! Also doesn't help as there are 3 leads on one of the connectors which are not connected at all! Looks like I'll have to get the plugs as well and splice the old wiring in. Quote Link to comment Share on other sites More sharing options...
Steve Posted April 8, 2008 Share Posted April 8, 2008 do you think the car has been in a flood at some point? Quote Link to comment Share on other sites More sharing options...
thebaldone Posted April 8, 2008 Author Share Posted April 8, 2008 do you think the car has been in a flood at some point? Looking at the state of the plugs left then I'd say yes! They are in a pretty bad way so I am going to try and get 2 plus a bit of the loom and splice them back in again. Oh what fun!! I have found a link on another forum which shows you how to bypass the ECU altogether if it's gone bad and can't be replaced. All it uses is a single 4 connector relay and other people have successfully got it working fine using this method !! Quote Link to comment Share on other sites More sharing options...
