gayjay86 Posted August 11, 2014 Share Posted August 11, 2014 I have a 1998® Ford Escort Saloon.. on taking up drive & sometimes when driving along it knocks from what seems to be the gearbox end.. i have already replaced CV joints as they melted(due to brakes jamming on & me just keep on going) causing driveshaft to drop out so replaced all brakes ie discs, pads & calipers aswell as cv joints but now its knocking.. could i have damaged the driveshaft itself or have i knackered the gearbox end the driveshaft goes into?? Its almost like a pinging and a knock at same time if that makes any sense when you pull away but then jus knocks.. and also even tho brskes have all been replaced & fluid changed and bled properly the passenger side brake still sticks.. its freeing up slowly but when i dun a 600mile trip with it if i had to brake hard coz of dickhed drivers pulling out on me i had to stop n wait before i could drive again coz it would be jammed on.. Not good on the motorway when someone pulls out on you that you then have to stop.. gggrrrr any advice would be appreciated.. GayJay's Galaxy S4 Quote Link to comment Share on other sites More sharing options...
AJRTDDI Posted August 15, 2014 Share Posted August 15, 2014 Bottom arm bushes or balljoints maybe Quote Link to comment Share on other sites More sharing options...
AJRTDDI Posted August 15, 2014 Share Posted August 15, 2014 Also u need to get the caliper fixxed if it's still sticking. Quote Link to comment Share on other sites More sharing options...
gayjay86 Posted August 15, 2014 Author Share Posted August 15, 2014 Ball joint and bushes were replaced for the MOT last year.. !Removed! car!! Lol Quote Link to comment Share on other sites More sharing options...
AJRTDDI Posted August 15, 2014 Share Posted August 15, 2014 Was the brakes all from scrap yard ? Quote Link to comment Share on other sites More sharing options...
gayjay86 Posted August 15, 2014 Author Share Posted August 15, 2014 The caliper seems to be freeing up & apart from shooting right under braking its alot better than it was, it doesnt really get used much so wondering if the brakes need bedding in properly?? When you dip the clutch to change gear it kinda pulls to the left.. almost feels like the steering wheel isnt connected if that makes sense.. iv gotten use to movinf the steering wheel to accomadate the pulling left when changing gear and same wi braking but i darnt let any1 else drive it.. Quote Link to comment Share on other sites More sharing options...
gayjay86 Posted August 15, 2014 Author Share Posted August 15, 2014 Brakes were all brought new from Car accessory shop Wilcos,i assume the caliper could have been reconditioned coz they gave me a tenner back for taking them my old caliper... Quote Link to comment Share on other sites More sharing options...
AJRTDDI Posted August 15, 2014 Share Posted August 15, 2014 Car shouldn't pull to left when you change gear unless your riding the throttle/accelerating at same time? When changed the cv boots was driveshafts in good condition no knocking or movement? Quote Link to comment Share on other sites More sharing options...
gayjay86 Posted August 15, 2014 Author Share Posted August 15, 2014 It started knocking about 3 days after CV Joints were replaced.. the driveshaft looked ok, but needed it drivable so tbh it looked ok so just put driveshaft back on.. buts it started knocking from Gearbox area 3 days after cv joints were replaced.. i drive it the same as i always have dun so we can only assume that the pulling left is to do with the driveshaft.. Quote Link to comment Share on other sites More sharing options...
AJRTDDI Posted August 15, 2014 Share Posted August 15, 2014 Did u do the work yourself ? Quote Link to comment Share on other sites More sharing options...
gayjay86 Posted August 15, 2014 Author Share Posted August 15, 2014 Iv got the chance to replace my Escort with a new Vectra @ end of the month but iv tried before & cant bring myself to get rid of my faithful, reliable Escort.. lol.. plus iv spent soo much on it this year, its not worth selling now anyway,i may aswell just get driveshaft (if that is the problem) replaced n weld the exhaust coz thats all it needs.. but if iv damaged the gearbox then i will cut my losses coz thats too big a job for me to do at the roadside coz nowhere else to do it atm.. Quote Link to comment Share on other sites More sharing options...
gayjay86 Posted August 15, 2014 Author Share Posted August 15, 2014 Me & my dad dun it.. my dads fixed all his own cars & lots of other peoples etc for the last 20yrs so it was dun properly.. Quote Link to comment Share on other sites More sharing options...
AJRTDDI Posted August 15, 2014 Share Posted August 15, 2014 It's hard one. Cause I can't physical feel the driveshafts to see if there's any play. But what worries me is u may been driving with it brakes sticking can cause a lot of internal stain on your gearbox. The escort gearbox aren't weak points of the car so u may have a damaged driveshaft. Quote Link to comment Share on other sites More sharing options...
gayjay86 Posted August 15, 2014 Author Share Posted August 15, 2014 Thankyou.. what il do next month is replace the driveshaft an see what its like.. do you think its ok to just replace passenger side driveshaft or should they both be replaced.. Coz i couldnt be without a car, instead of replacing the caliper i just kept goin which has caused more problems, the old brake pads had crumbled & the old discs were badly warped then melted CV joint so that will teach for ignoring it.. im praying i havent damage the gearbox coz i really do love my Escort & iv never liked a car enough to keep it for 3 yrs.. normally after 6 months im bored n theyre out the door.. iv left many Audi TT's & boy racers standing in my old escort, without even trying.. But i do know she is well overdue a service but i dont want to do that until i know everything else is right, incase iv damages gearbox, i may have to scrap it even tho i dont want to.. Quote Link to comment Share on other sites More sharing options...
AJRTDDI Posted August 15, 2014 Share Posted August 15, 2014 I don't recommend this but. I'd put it on axle stands and let it tick over in 2nd and see if noise reacures when wheels are spinning. Quote Link to comment Share on other sites More sharing options...
gayjay86 Posted August 15, 2014 Author Share Posted August 15, 2014 It seems to do it as you lift off the clutch to take up drive & over bumps.. i was wondering if the pulling to left when changing gear could have anything to do with shock absorbers?? They seem to be fine but my back ones seemed fine and kept goin thru MOT even tho i knew they had had it 2 MOT's ago and altho they seemed fine if you bounced them driving along they used to bang and when we changed them, they were that bad, it had snapped the springs aswell.. but im soo worried about spending too much money that i dont have, to find its not that but summin else if you can understand that.. i cant afford to take it to a garage to get it looked at either.. so i think, its guna be a case of slowly replacing everything bit by bit.. it only gets used for the long runs now, i only drive it around town once a week to keep everything ticking over.. Quote Link to comment Share on other sites More sharing options...
AJRTDDI Posted August 15, 2014 Share Posted August 15, 2014 My parents have a galaxy with over 350,000 miles shocks have been gone for 5 years no return when compressed and never failed. Lol I dont think shocks can cause it car to pull to one side. Is it same side it brakes are sticking Quote Link to comment Share on other sites More sharing options...
gayjay86 Posted August 15, 2014 Author Share Posted August 15, 2014 The passenger side brake sticks if ya have to brake hard & it pulls to the right under hard braking & pulls to the left when changing gear.. Very strange.. i think its coz i drive a different (small KA) car around town that im noticing all these faults more i think.. id gotten so used to everything gradually goin that i never payed any attention when it was the only car i was using but after driving a different car, its all way too noticable.. The KA feels like a merc compared to my Escort atm.. lol.. and the strange thing is the KA seats are actually more comfortable on a longer journey than my escorts aswell but theres nothing like my own car to drive tho.. its a nice enough car to drive but i hate driving my mates KA.. lol Quote Link to comment Share on other sites More sharing options...
AJRTDDI Posted August 15, 2014 Share Posted August 15, 2014 U could have too faults by sound of it maybe sticky caliper and driveshaft Quote Link to comment Share on other sites More sharing options...
gayjay86 Posted August 15, 2014 Author Share Posted August 15, 2014 Could it have been a dodgy caliper i got then? It will ave to wait til next month now but il ask my dad to strip the caliper down when he does the driveshaft.. do you think it will b ok jus to replace passemger driveshaft or should i replace drivers side at same time.. i know if 1 goes the others prob not far off unless i did damage it.. but if i can jus chamge the pass side to see if it stops it before i spend out on the otherside, it would make findin the money abit more easier, especially if it turns out iv caused damage to gearbox.. Quote Link to comment Share on other sites More sharing options...
AJRTDDI Posted August 15, 2014 Share Posted August 15, 2014 If it's sticking yea.. could need sliders Greasing. Yea one driveshaft is fine to change. Quote Link to comment Share on other sites More sharing options...
gayjay86 Posted August 15, 2014 Author Share Posted August 15, 2014 Ok kool thankyou.. i will let you kno what we find wrong wi brakes n if a new driveshafts fixes the problem.. Quote Link to comment Share on other sites More sharing options...
glodenspanner Posted September 3, 2014 Share Posted September 3, 2014 Droplinks maybe they knock n clunk over ruff when rubbers perish Quote Link to comment Share on other sites More sharing options...
