Slupanter Posted November 14, 2014 Share Posted November 14, 2014 Hi all, My faulty ST again :( Does anyone else get stutter/jerks of power loss in 6th at 40. Not labour but power cuts Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
alexp999 Posted November 14, 2014 Share Posted November 14, 2014 6th at 40? Isn't that a bit low, don't think my car could cope with that... 1 Quote Link to comment Share on other sites More sharing options...
chrisroberson99 Posted November 14, 2014 Share Posted November 14, 2014 I agree with Alex. I may not drive on roads but when I've driven, never been in 6th under 60! Quote Link to comment Share on other sites More sharing options...
Slupanter Posted November 14, 2014 Author Share Posted November 14, 2014 I would agree but it tells you to and it's not like a stalling stutter but more like a miss fire Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
alexp999 Posted November 14, 2014 Share Posted November 14, 2014 I don't know how the ST is geared, but mine only just accepts 6th at 50. 6th is an incredibly high gear, all economy no power. What happens if you try 5th at 30? Quote Link to comment Share on other sites More sharing options...
peterbrooks Posted November 14, 2014 Share Posted November 14, 2014 I have a 2014 focus zetec s 1.0 ecoboost and I find that when it tells you to change into sixth Its usually between 40 and 45 I leave it to nearer 45mph otherwise I find the gear is to high for the speed but it also depends on the gradient of the road. But more often than not I tend to use sixth gear on dual carriageways motorways or long roads were my speed is constant.so I don't think it's a fault! I think it's a case of using your own judgement when your selecting sixth gear but if I was you I'd try changing at around 45mph and you should find that the car is a lot happier Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
Rossbclarke123 Posted November 14, 2014 Share Posted November 14, 2014 I agree 6th in 40 is to slow and would make the car struggle Quote Link to comment Share on other sites More sharing options...
troy45 Posted November 14, 2014 Share Posted November 14, 2014 My ST would be pulling 1500 rpm at that speed in top gear, definitely too low for it to run smoothly. Quote Link to comment Share on other sites More sharing options...
artscot79 Posted November 14, 2014 Share Posted November 14, 2014 On a 5th gear car its just about okay to sit in 5th at 40 6th is a cruising speed as is fifth so i agree its too early to be changing up it does also depend on fuel the st to have peak power needs premium fuel bog standard unleaded changes the map giving less power and response which wont help ide leave 6th for 50mph and over Quote Link to comment Share on other sites More sharing options...
Slupanter Posted November 14, 2014 Author Share Posted November 14, 2014 Thanks guys On a side troy, what fuel is best? I my Shell V power man but do you guy recommend something else ? Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
troy45 Posted November 14, 2014 Share Posted November 14, 2014 Thanks guys On a side troy, what fuel is best? I my shell V power man but do you guy recommend something else ? Actually tried running mine at 40mph in 6th this evening and it burbled along nicely enough - could be the mk3 is a little bit less flexible down at those rpm's due to the smaller 2.0L engine? plus mine is far from standard trim these days. Fuel-wise I use the Shell Nitro V-Power in mine, doesn't hurt to put the best stuff in it whenever I can. Never really run the BP equivalent for any length of time, it's a lot more expensive from the garage nearest to me. Quote Link to comment Share on other sites More sharing options...
Slupanter Posted November 15, 2014 Author Share Posted November 15, 2014 I'm just going to keep 6th for 45-50 now. Stupid shift up sign. I've tried BP 97 but find it abit crap. Love total super tho. I find it's like rocket fuel. Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
artscot79 Posted November 15, 2014 Share Posted November 15, 2014 Ide keep an eye on it and if youve any worries take it to the dealers for a check Quote Link to comment Share on other sites More sharing options...
Scott Hoffbauer Posted August 13, 2017 Share Posted August 13, 2017 I have 2013 ST and able to drive 35 in 6th, you wouldn't want to do a hard acceleration but it's possible. Quote Link to comment Share on other sites More sharing options...
DJ_Andy_M Posted August 13, 2017 Share Posted August 13, 2017 2 hours ago, Scott Hoffbauer said: I have 2013 ST and able to drive 35 in 6th, you wouldn't want to do a hard acceleration but it's possible. And you've just bumped this VERY OLD post from 2014 just to say that? 1 Quote Link to comment Share on other sites More sharing options...
