Mk7.5 Speaker Upgrade
Hey all Im thinking of upgrading my speakers in car but keeping my sony unit (titanium) the speakers are sound system is enough but i hate when you get a bass song and speakers cant handle it basically but problem is ive never done it before and dont know what to get so links and info would help alot as first time fore everything :D i have been reading about the forum but would need a little help about this one as im new to it (hate to admit it XD)
thanks in advance :D
  • Replies 214
  • Views 58.1k
  • GingerFlame
    GingerFlame
    I would disconnect the battery & turn on the ignition the discharge everything, try to turn the radio on too. Then go make a cuppa, come back and unplug stuff You should be fine without but with a
  • Photo's will be good enough, but be sure to have as many as possible ^_^ (create a guide, that's "idiot" proof) :D
  • Any photos of this set up please? As me being a fan of Trance/Funky House... I do like some base. But dislike the rattling door cards! :D I used to have a JBL sub/amp installed in the boot of my pr
Ford sell pioneer kits that are plug and play, look up the accessory brochure on line.
They any good tho?
If you just want deeper bass, then consider adding a subwoofer as that would be adequate for your needs. New speakers will probably not give you that bass that you are looking for. There are different types of subwoofer and reading up about them might help you narrow your choices.
Have a look at my thread for info.
http://www.fordownersclub.com/forums/topic/52338-hassens-ford-focus-16-tdci-build-thread/
naw buddy just the speakers as even if added subwoofer speakers would still make daft noises its more of a clearer base lol
If you fitted a sub, for example an underseat active sub, you could cut the bass from the door speakers so they would only do the mid/treble. Less reason for the door speakers to vibrate and make daft noises.
As always cheers Mark might do both then :) thanks bud
I have added aftermarket sub turned the Base right down on the radio but there is still plenty of bass comming from the sub without the door cards vibrating.
How did you add it in? Are they a plug at back is system or what? Buddy
Underseat powered subwoofer would be the best bet I think without breaking the bank. At a later stage, you can always get a coaxial set of speakers to have clearer mids and high frequency.
How do you wire the underwear sub ? I'm new to this sort of thing
installed a sub with high pass filters built in and wired in to rear speakers
I used to have a JBL sub/amp installed in the boot of my previous Clio. With a alpine head unit the sound was fantastic, but I lost half of the boot space because of the sub/amp. Don't really want to have this in the Fiesta, and I like to have ample boot space.
Plus one to that
will try and post some pics up tomorrow.
http://www.thompsonsltd.co.uk/brands-bass-face/power12.2-bass-face-2600w-double-12-active-powered-car-sub-box-subwoofer-amplifier-amp.html
this is the sub i got unfortunately it does take up half the boot and is a bit ott.
http://www.thompsonsltd.co.uk/brands-bass-face/power12.1-bass-face-12-1300w-car-sub-box-subwoofer-and-built-in-amplifier-powered-package.html
this one would probably do the job and give you more boot space
Under seat subs? And can you have two ?
mine isn't an under seat sub it goes in the boot. its 2 12" subs in one enclosure with built in amp. i may well have gone for an under seat sub if i didn't already have this one from last car
A checked it out mate what speakers fit in place directly? Plug n play
you dont need them plug and play just get these
http://www.ebay.co.uk/itm/FORD-FIESTA-MK7-2008-on-SPEAKER-ADAPTOR-KIT-COLLARS-/380695025936?pt=LH_DefaultDomain_3&hash=item58a3311910
then any 16.5mm speakers
some of these
http://www.ebay.co.uk/itm/100x-Blue-Scotch-Lock-Wire-Connectors-Quick-Splice-Terminals-Crimp-Electrical-/251001987313?pt=LH_DefaultDomain_3&hash=item3a70e260f1
then you can have the speakers of your choice and keep the original wiring intact
speaker sizes are same front and rear not sure on tweeters
Best thing would be to get some decent components are replace the tweeters, Alpine ones aren't too badly priced tbh about £140 a pair for decent lines.
the rattles you'll never stop, I remember mine wasn't the door cars or trims that rattled it was the switch for the mirror adjustment that always rattled, the rest of the car was spot on for this. just touching the sliver switched and it stopped. quite annoying.
not so bad then
its not a rattle is my problem the front left speaker is goosed lol takes no base a think its burst but cba getting it fixed as i want something that can handle a bit more bud :)
some of these
Can I cut off plug from old speaker for new speaker? And how hard is this sounds simple but being me a over think
You not got a soldering iron? You can buy the clips separately and have any speaker you like, cost pence and take seconds to fit to the wire in reality.
