iantt Posted July 15, 2023 Share Posted July 15, 2023 3 hours ago, metmusic said: Hi iantt, do you have full failure tone list? Thanks in advance What vehicle is the list for? Quote Link to comment Share on other sites More sharing options...
metmusic Posted July 15, 2023 Share Posted July 15, 2023 33 minutes ago, iantt said: What vehicle is the list for? Fiesta MK7 (2009) Quote Link to comment Share on other sites More sharing options...
iantt Posted July 15, 2023 Share Posted July 15, 2023 2 minutes ago, metmusic said: Fiesta MK7 (2009) Ok, will see what I can find. Quote Link to comment Share on other sites More sharing options...
iantt Posted July 15, 2023 Share Posted July 15, 2023 1 Quote Link to comment Share on other sites More sharing options...
metmusic Posted July 15, 2023 Share Posted July 15, 2023 Many thanks mate! Quote Link to comment Share on other sites More sharing options...
Stuart124 Posted September 24, 2023 Share Posted September 24, 2023 Hi guys. I have a problem with my daughters 2012 fiesta diesels parking sensors. I get a 3 second warning sound followed by a single bleep when I either select reverse or press the parking aid button below the radio. I have tested both the front and rear souders, each test at 49 Ohms! Any ideas what it might be? Quote Link to comment Share on other sites More sharing options...
unofix Posted September 24, 2023 Share Posted September 24, 2023 @iantt is the 'Beeping' expert on this !! You can use FORScan and it will tell you what the problem is, which is possibly just a failed sensor. Quote Link to comment Share on other sites More sharing options...
iantt Posted September 24, 2023 Share Posted September 24, 2023 If you look at the beeping chart above, you will see 3second warning and then 1 beep is an issue with the front left outer sensor or wiring. Try swapping a sensor and see if the beeping changes, if not sensor ok and then possible wiring issue. 1 Quote Link to comment Share on other sites More sharing options...
Stuart124 Posted September 28, 2023 Share Posted September 28, 2023 Thanks for the above replies guys, I've swapped over two sensors (both front outers) and the warning is still one bleep. looks like a wiring issue. Just to double check which one is the left outer? is it left as you look at the car or left as if your sat in it? Near side or off side? I'll check the wiring this weekend. Quote Link to comment Share on other sites More sharing options...
unofix Posted September 28, 2023 Share Posted September 28, 2023 Left as if you were sat in the car. 1 Quote Link to comment Share on other sites More sharing options...
Stuart124 Posted September 28, 2023 Share Posted September 28, 2023 Fantastic, cheers Unofix. Quote Link to comment Share on other sites More sharing options...
Stuart124 Posted October 3, 2023 Share Posted October 3, 2023 Gent's. Problem fixed, I found a broken wire leading to the front left sensor at the weekend. All repaired. Cheers lads. 2 Quote Link to comment Share on other sites More sharing options...
char0144 Posted January 21 Share Posted January 21 hi all i have a 2011 fiesta with rear sensors only. i found this thread while chasing the fault tone meanings. i have a long tone followed by 6 beeps. @iantt you have added screen shots of all the codes. would it be possible to add the 6 beeps action, i cannot see it on the screen shots. thank you Quote Link to comment Share on other sites More sharing options...
Rob_H Posted February 5 Share Posted February 5 @char0144 - I too have this same issue - and it's the only Beep count that I cannot find! @iantt Any help would be gratefully received. Many thanks Quote Link to comment Share on other sites More sharing options...
iantt Posted February 6 Share Posted February 6 1 Quote Link to comment Share on other sites More sharing options...
Rob_H Posted February 12 Share Posted February 12 Thanks Iantt! - you're a star. Next Question - Any idea what VBatt is? - My guess is battery Voltage? in which case, does this suggest a supply issue to the Park Assist Module? Quote Link to comment Share on other sites More sharing options...
