Rear parking sensors
Hello all you brains out there
My parking sensors have stopped
all i get when i select Reverse is a long beep then nothing until i turn off engine then the next time i start and select reverse a long beep then nothing Etc Etc
does anyone know if i unplugged all of the sensors and then tried reverse should i still hear a beep or not ?
i am assuming that if i took it to a garage it might be expensive ?
is there any way i can test the Parking aid module ?
I've tried a code reader and no codes stored and I've tried the dash self test
obviously I've cleaned sensors
any help?thoughts would be fantastic
Focus 2.0 titanium automatic
Had a similar issue with mine, I selected reverse with ignition on I then unplugged each sensor in turn until the constant beep went off, I managed to find the sensor that was playing up by putting my hand over each sensor in turn popped it out of the bumper gave it good clean put it all back together and it solved the problem
Select reverse with ignition on get down on hands and knees and put ear to each sensor a healthy sensor emits a ticking noise .......
give them a clean, usually works for me!
Thanks for the replies but i have cleaned them taken them out etc etc
my car is automatic so can't leave it reverse (scares me)
i have 1 beep which lasts for 3 seconds then no noise
thats why i was wondering if it was a fault with the Parking aid module but don't want to waste £50 on a replacement
When he said put it in reverse with the ignition on he doesn't mean with the car running, turn the key till your dash lights come on, then select reverse (it's one position before you actually start the car, position 2 if I remember correctly)
Its an automatic so gear lever will not move unless engine is running
well I'm bad
i just did it key to pos 2 lever moved to rev
3 out of 4 sensors were clicking
so i have a bad sensor ?
9 minutes ago, dfoord said:
well I'm bad
Yeah had to put foot on brake pedal to get lever to move
well i learnt something everyday whoo hoo
thanks Russ you are a diamond
it would be nice if i could get a new sensor colour coded ? or it will have to be 1 odd black one
thanks again
i have just ordered a replacement sensor just hope it works
new sensor in works perfectly
  • 3 years later...
my ford focus 2015 model packing sensor not working when i turn the ignition on it says "packing sensor malfunction needs services" any idea on whats might wrong?
If you’ve got an elm cable and forscan. It will tell you the problem.
