lewis1982 Posted May 8, 2016 Share Posted May 8, 2016 Hello I have a 2008 ford focus 1.5 diesel last year I had to have a new engine put it cause I bought a dodgy car, less than 10 months later and the engine malfunction light has come on but when Ive tried the dashboard trick that has been mentioned on some of the other forums there are no codes. Anyone got any ideas what the problem could be Thanks in advance Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted May 8, 2016 Share Posted May 8, 2016 It could be loads of things. You need the fault codes read properly, dash test isn't great tbh. If you've got a laptop or smart phone, get an ELM cable or bluetooth dongle and read the codes using FORScan. Quote Link to comment Share on other sites More sharing options...
lewis1982 Posted May 8, 2016 Author Share Posted May 8, 2016 15 minutes ago, TomsFocus said: It could be loads of things. You need the fault codes read properly, dash test isn't great tbh. If you've got a laptop or smart phone, get an ELM cable or Bluetooth dongle and read the codes using FORScan. Hi Tom Ive ran three different plug in devices now all of them get live readings from the car when its turned on but none of them are showing any faults an elm 327 interface a laptop and a specialist one too thanks Lewis Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted May 8, 2016 Share Posted May 8, 2016 Hmm, ok that's odd! Could be a cluster fault. Quote Link to comment Share on other sites More sharing options...
