Noonie Posted September 7, 2016 Share Posted September 7, 2016 Hi all, so I changed my wheels to St alloys and now my tpms on my computer says that I have to retrain it. I've looked on video's on YouTube, read forums and tried the ways suggested,but to no joy. Has anyone here had same problem and cracked it, would appreciate any information. Cheers. Quote Link to comment Share on other sites More sharing options...
iantt Posted September 7, 2016 Share Posted September 7, 2016 have you driven it far? Quote Link to comment Share on other sites More sharing options...
JW1982 Posted September 7, 2016 Share Posted September 7, 2016 Do the wheels have the (correct type) TPMS sensors? The TPMS systems was introduced on the Focus MK3 after approximately the 2nd half of 2014. Older Focus MK3 vehicles did have the (optional) DDS system which uses the ABS sensors. The DDS systems is often incorrectly called TPMS. The TPMS system on the late Focus MK3 and Focus MK3.5 is basically a self learning system. After the wheels or sensors are changed the TPMS system must be reset (from inside the instrument cluster settings menu) and the car must be driven for at least 12 minutes to pair the new sensors with the system. Quote Link to comment Share on other sites More sharing options...
Noonie Posted September 7, 2016 Author Share Posted September 7, 2016 The wheel's are from a Mondeo at 59 plate, my focus is a 15 plate, so mk3.5. I knew you could retrain the computer, but I've tried suggestions like I said in my first post but my car doesn't seem to follow the commands I'm trying to put in. Quote Link to comment Share on other sites More sharing options...
iantt Posted September 7, 2016 Share Posted September 7, 2016 are the sensors off the mondeo or focus? Quote Link to comment Share on other sites More sharing options...
iantt Posted September 7, 2016 Share Posted September 7, 2016 the tpms from 59 mondeo are different to the focus 15 plate system Quote Link to comment Share on other sites More sharing options...
Noonie Posted September 7, 2016 Author Share Posted September 7, 2016 Sensors are off focus Quote Link to comment Share on other sites More sharing options...
iantt Posted September 7, 2016 Share Posted September 7, 2016 should be ok then, have you driven it after resetting in cluster menu? Quote Link to comment Share on other sites More sharing options...
Noonie Posted September 8, 2016 Author Share Posted September 8, 2016 Yes reset the dashboard computer, but not retrained it. Quote Link to comment Share on other sites More sharing options...
huey45 Posted September 11, 2016 Share Posted September 11, 2016 I have a 2015 Mk3.5 where are the sensors fitted on my Titanium ?, all I get after inflating tyres, I have the option to reset the system settings but it does not give individual warnings just tyre pressure low, then I have to check each tyre in turn, to find out where ?? Quote Link to comment Share on other sites More sharing options...
iantt Posted September 11, 2016 Share Posted September 11, 2016 sensors are atatched to the tyre valves, you wont get individual warnings . think only mondeo, s max galaxy gives individual tyre pressure readings Quote Link to comment Share on other sites More sharing options...
