jabbsy83 Posted October 14, 2016 Share Posted October 14, 2016 Hello guys I have lowered my mk 2.5 focus zetec 30mm and I must admit it looks lurvly 😄 was wondering would it be worth me putting 5mm spacers all round. I have been offered 4 for £40. Any feedback would be great. I could however double them up and have them at 10mm on the rear. If I did would they go straight on without effecting the thread and nut. Thanks in advance .. Quote Link to comment Share on other sites More sharing options...
Rainydays Posted October 15, 2016 Share Posted October 15, 2016 Hello guys I have lowered my mk 2.5 focus zetec 30mm and I must admit it looks lurvly [emoji1] was wondering would it be worth me putting 5mm spacers all round. I have been offered 4 for £40. Any feedback would be great. I could however double them up and have them at 10mm on the rear. If I did would they go straight on without effecting the thread and nut. Thanks in advance .. I have looked into spacers for my MK3 but I have had confusing answers. Maybe this thread can help me as well :). Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
jabbsy83 Posted October 15, 2016 Author Share Posted October 15, 2016 I have been told by a fitter that 5mm will go on perfect no issues. However 10mm may be a little tricky. He said if you can't put 10mm on then put 5mm all round. But the best way to know if 10mm would go is the nut must make at least 6 full turns on the tread. Hope this helps. I'm going to double them up and count if it turns 6 or more I'll leave them if it don't then I will place them on the front also. 1 Quote Link to comment Share on other sites More sharing options...
Rainydays Posted October 15, 2016 Share Posted October 15, 2016 I decided to buy a very expensive tool to mesure the gap. Now given that I do not have a third hand to measure while I take a picture, I can confirm that 5mm should fit without hitting the wheel arch. The space is there for all wheels and 5mm per wheel is 10 mm per axle. This will widen the track a bit and give better cornering. I also spoke to some people and while they confirmed 5mm should work I have yet to see it in action. Please find below my expensive tool :). Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
jabbsy83 Posted October 15, 2016 Author Share Posted October 15, 2016 Could you please confirm where you bought this tool as I would love to purchase one. I bet this wasn't cheap Quote Link to comment Share on other sites More sharing options...
JW1982 Posted October 15, 2016 Share Posted October 15, 2016 The dimensions of wheel spacers are usually listed per axle. The wheel hubs have a machined flange which is needed to keep the brake discs and the wheels centered on the hub. The thinner type wheel spacers are usually just flat and are mounted on the wheel hub between the wheel and the brake disc. This type of wheel spacers should only be used for thin spacers. In my opinion 3 mm will be the maximum thickness for this type of spacer. When using thicker spacers of this type the spacer the wheel is no longer sufficiently centered on the wheel hub. Not having the wheels centered correctly onto the wheel hub will result in vibrations. In my opinion it is much better to use slightly thicker wheel spacers which have their own machined flange to keep the wheel centered. These spacers are available in different designs depending on thickness of the spacer. Next to this it important to use good quality wheel spacers. You do not want this to happen: 1 Quote Link to comment Share on other sites More sharing options...
biff55 Posted October 15, 2016 Share Posted October 15, 2016 all things considered , i wouldnt bother. 5mm wont be noticable enough to create any sort visually aggressive stance if its just for looks....... going bigger , eg 10 - 20mm , will require better quality and more expensive hardware , not to mention any impact with tram-lining , strain on wheel bearings etc etc. 1 Quote Link to comment Share on other sites More sharing options...
jabbsy83 Posted October 15, 2016 Author Share Posted October 15, 2016 I don't know if it makes a difference but my focus as drums on the back 🔧 Quote Link to comment Share on other sites More sharing options...
kyle_saloontdci Posted October 15, 2016 Share Posted October 15, 2016 I've put 2 of these on the rear of my focus and they have been fine. I wouldn't risk going 10mm unless you fit longer studs to make up for the spacer being on. Ideally I want 15mm front and 20mm rear hubcentric spacers which bolt on and the wheel bolts to that but I can't justify the price of them [emoji51][emoji51] I didn't pay much more for my 18s and brand new tyres. To be honest 5mm is tiny and I doubt you can tell I've spaced my rears so unless you're doing it to clear bigger brakes or something it's not overly worth doing but if you do I'd order some universal ones like in the pic off of eBay than paying £40 for some as you'd be better putting the £40 towards proper hubcentric ones which will make a noticeable difference Sent from my iPhone using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
Rainydays Posted October 15, 2016 Share Posted October 15, 2016 Tons of good information here. 15 front and 20 back are the ST recommended spacers. Eibach has a nice pair with TUV and I wanted to get those. Thing is, i need to get wheel nuts and studs most probably. Which in turn will force me to buy 18 winter alloys because those won't fit on 16 winter alloys :(. Sent from my iPhone using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
