540itouring Posted May 20, 2017 Share Posted May 20, 2017 Hi , I have just got a interior light with intrusion detector from a 2012 ranger , swapped over the location blue LEDs with the orange ones from the old light. I then added tree wires for the power , ground and data for the extra ultrasonic sensor and then reprogrammed the body computer to enable its options and control via the front display monitor. Just tested the alarm with window down and all works perfect . Last upgrade to do is add front parking sensors , parking switch and bumper wiring for sensors and reprogram the body computer again. other mods completed was adding Tyre Deflation monitoring (now all working) and Navigation System all working with Miles/Km selection and Sync upgraded to 1.1 (all working) Also added factory fit Reverse Camera with lines controlled by steering wheel position (all working) Pics to follow later Quote Link to comment Share on other sites More sharing options...
N.K.D Posted August 16, 2017 Share Posted August 16, 2017 On 5/21/2017 at 0:34 AM, 540itouring said: Hi , I have just got a interior light with intrusion detector from a 2012 ranger , swapped over the location blue LEDs with the orange ones from the old light. I then added tree wires for the power , ground and data for the extra ultrasonic sensor and then reprogrammed the body computer to enable its options and control via the front display monitor. Just tested the alarm with window down and all works perfect . Last upgrade to do is add front parking sensors , parking switch and bumper wiring for sensors and reprogram the body computer again. other mods completed was adding Tyre Deflation monitoring (now all working) and Navigation System all working with Miles/Km selection and Sync upgraded to 1.1 (all working) Also added factory fit Reverse Camera with lines controlled by steering wheel position (all working) Pics to follow later How about your project? Could you upload picture of wiring? Quote Link to comment Share on other sites More sharing options...
