rhyds Posted February 18, 2018 Share Posted February 18, 2018 Having had a quick look around the forum it seems that Xtrons head units are a popular upgrade. However I'm still not clear on a few things 1: Which is the best unit to get? I'm not interested in having a DVD player so the choice seems to be between Android 7.1 and Android 8. What are people's experiences? 2: Are there any recommended sellers? 3: I'm looking at having a DAB unit, does the Xtrons have the DAB tuner built in or is it an external dongle? Also, is it possible to plug the Xtrons DAB tuner/Dongle in to a standard Focus DAB aerial? 4: Will the GPS antenna/unit work behind the dash or does it need mounting behind the A-pillar trim? Quote Link to comment Share on other sites More sharing options...
Micro Posted February 18, 2018 Share Posted February 18, 2018 My GPS antenna is on top of the metal support under the dash, professionally secured with duct tape... Which model are you looking at? Quote Link to comment Share on other sites More sharing options...
rhyds Posted February 18, 2018 Author Share Posted February 18, 2018 My GPS antenna is on top of the metal support under the dash, professionally secured with duct tape... Which model are you looking at?Duct tape: the finest of mounting systemsI've been looking at this unithttps://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F202022690327 1 Quote Link to comment Share on other sites More sharing options...
Incontro Posted February 18, 2018 Share Posted February 18, 2018 I didn't buy an 'xtron' unit, but from a different seller. Very happy with mine, bought it about 3-4 years ago, not a single issue since. I've simply placed my GPS antenna flat on the left hand corner of the dash (up near the glass where the windshield slopes up), and it works perfectly fine. Secured with blue-tack lol, but it's never moved once. Quote Link to comment Share on other sites More sharing options...
Micro Posted February 18, 2018 Share Posted February 18, 2018 That's one of the new quad core models, Xda-developers have a load of information on them on their website. The price has come down a little, I paid £227 for mine about 2-3 years ago. I updated mine with custom firmware but it is still a little slow on occasion (especially whilst using the wifi network), when trying to do multiple things. Mine is one of the older ones but the external case looks the same - the DAB is an external dongle that may or may not be included (check the description carefully) - i'm not sure if it'll plug and play with the Focus antenna but probably will knowing the rest of the wiring is plug and play to the quad-lock connector. The reverse signal is interpreted from the canbus network and there is an option to either get ignition status from the canbus or the ignition terminal in your quadlock (if it's there). Quote Link to comment Share on other sites More sharing options...
rhyds Posted February 18, 2018 Author Share Posted February 18, 2018 Thanks for the info. TBH I'm not sure how much hacking/modding of it I'll be doing, but its nice to know there's some 3rd party development for it. Quote Link to comment Share on other sites More sharing options...
Jonnyvr46 Posted February 20, 2018 Share Posted February 20, 2018 Hi sorry to hijack the thread, but how simple are these to install? Never done anything like it before, is it a very simple take the old stereo out unplug it and plug the new one in? Quote Link to comment Share on other sites More sharing options...
rhyds Posted February 20, 2018 Author Share Posted February 20, 2018 7 hours ago, Jonnyvr46 said: Hi sorry to hijack the thread, but how simple are these to install? Never done anything like it before, is it a very simple take the old stereo out unplug it and plug the new one in? There's probably a how-to somewhere on here, but in general, on a MK2.5/Facelift it goes like this: 1: Make sure you have the code! 2: Unclip the plastic surround that goes around the radio and heater controls, a small lever will be needed to start it off but it should come away reasonably easily 3: Once the surround is off the head unit itself is held in by 4 screws, take these out and the radio will come away. You'll need to release the quadlock connector (there's a lever that pulls up to do this) and the radio aerial(s) and the unit will come out 4: If you've got bluetooth/voice control then I'm told the unit (behind the glovebox) needs to be disconnected if you're not using a Ford head unit As for installing the Xtrons unit, from what I gather it has a quadlock connector on it so should plug straight in, and you'll have to find places for any add-ons you've gone for (GPS etc.) Quote Link to comment Share on other sites More sharing options...
Jonnyvr46 Posted February 27, 2018 Share Posted February 27, 2018 On 20/02/2018 at 8:47 PM, rhyds said: There's probably a how-to somewhere on here, but in general, on a MK2.5/Facelift it goes like this: 1: Make sure you have the code! 2: Unclip the plastic surround that goes around the radio and heater controls, a small lever will be needed to start it off but it should come away reasonably easily 3: Once the surround is off the head unit itself is held in by 4 screws, take these out and the radio will come away. You'll need to release the quadlock connector (there's a lever that pulls up to do this) and the radio aerial(s) and the unit will come out 4: If you've got bluetooth/voice control then I'm told the unit (behind the glovebox) needs to be disconnected if you're not using a Ford head unit As for installing the Xtrons unit, from what I gather it has a quadlock connector on it so should plug straight in, and you'll have to find places for any add-ons you've gone for (GPS etc.) Do you need to bother disconnecting the battery? Quote Link to comment Share on other sites More sharing options...
rhyds Posted February 27, 2018 Author Share Posted February 27, 2018 I didn't, but made sure the driver's window was open and the ignition key was in my pocket just in case! Quote Link to comment Share on other sites More sharing options...
Ferrit Posted February 27, 2018 Share Posted February 27, 2018 I've just put my xtrons in last night and can confirm that it is a easy 5 minute job. I didn't disconnect the battery either. Gonna have to pull the unit out again at the weekend to pop in the GPS antenna. Quote Link to comment Share on other sites More sharing options...
rhyds Posted February 27, 2018 Author Share Posted February 27, 2018 12 minutes ago, Ferrit said: I've just put my xtrons in last night and can confirm that it is a easy 5 minute job. I didn't disconnect the battery either. Gonna have to pull the unit out again at the weekend to pop in the GPS antenna. Where did you get your unit? Quote Link to comment Share on other sites More sharing options...
JONATHAN_11_80 Posted February 27, 2018 Share Posted February 27, 2018 Anyone know much about the eonon units??? Quote Link to comment Share on other sites More sharing options...
Ferrit Posted February 27, 2018 Share Posted February 27, 2018 50 minutes ago, rhyds said: Where did you get your unit? http://www.ebay.co.uk/itm/In-Dash-7-Car-Stereo-DVD-Android-7-1-GPS-WiFi-OBD2-DAB-Ford-S-Max-C-Max-Galaxy/183089098638?_trkparms=pageci%3A717b4aff-1beb-11e8-893c-74dbd1804a2c|parentrq%3Ad88232d31610ab135b66ef27ffff9797|iid%3A1&_trksid=p2481888.c100675.m4236 That is listing is for the mk2 but they have custom fit ones for the mk2.5 and standard double din units as well. 1 Quote Link to comment Share on other sites More sharing options...
rhyds Posted February 27, 2018 Author Share Posted February 27, 2018 Thanks chief! Quote Link to comment Share on other sites More sharing options...
EddyOS Posted April 25, 2018 Share Posted April 25, 2018 Quick hijack, but do any of you have rear parking sensors? And did they continue to work after swapping out the stereo for one of these Android ones? Quote Link to comment Share on other sites More sharing options...
Micro Posted April 28, 2018 Share Posted April 28, 2018 I have aftermarket sensors so yes, if you disconnect the factory radio you should be able to see if it will affect yours. Quote Link to comment Share on other sites More sharing options...
Painterchris Posted May 14, 2020 Share Posted May 14, 2020 Hi does anyone have any problems with battery drain with their XTRONS stereo Quote Link to comment Share on other sites More sharing options...
Luke4efc Posted May 14, 2020 Share Posted May 14, 2020 14 hours ago, Painterchris said: Hi does anyone have any problems with battery drain with their XTRONS stereo Nope, however any battery drain probably wont be the head unit itself, but the CANbus decoder box. 1 Quote Link to comment Share on other sites More sharing options...
Lenny Posted May 15, 2020 Share Posted May 15, 2020 On 5/14/2020 at 7:59 AM, Painterchris said: Hi does anyone have any problems with battery drain with their XTRONS stereo If this is a problem which you currently experience; then I'd advise you to fit a piggy back fuse adapter to a fuse which becomes live with the ignition such as the wipers, Then run a new cable to the headunit or device in question; Alternatively fit a switch 1 Quote Link to comment Share on other sites More sharing options...
FatHead1979 Posted May 16, 2020 Share Posted May 16, 2020 On 5/14/2020 at 7:59 AM, Painterchris said: Hi does anyone have any problems with battery drain with their XTRONS stereo Only when I had the ACC and permanent live mixed up when I initially installed the head unit, no problems in the 18 months since. 1 Quote Link to comment Share on other sites More sharing options...
jimmy.on Posted November 1, 2020 Share Posted November 1, 2020 Can I be another hijacker. I put a screen lock on and don't remember how I done it now I want to take it off. I can't find how to do this anywhere. it is android 10 installed on the system. Wonder if anyone can help please Quote Link to comment Share on other sites More sharing options...
FatHead1979 Posted November 1, 2020 Share Posted November 1, 2020 38 minutes ago, jimmy.on said: Can I be another hijacker. I put a screen lock on and don't remember how I done it now I want to take it off. I can't find how to do this anywhere. it is android 10 installed on the system. Wonder if anyone can help please I suspect you'll have to factory reset the unit, just as you would on a mobile phone. Quote Link to comment Share on other sites More sharing options...
