jeebowhite Posted December 26, 2010 Share Posted December 26, 2010 Hi Guys, Wanting to change the engine coolant, this will be a first so all advise is appreciated! I believe I have to: Jack the car up Remove the bottom "pan" Turn the "Nylon" plug and drain the radiator Add In New Coolant Now I have read a few things and want to clarify them if possible: 1) Where is the plug and is it easily visible from below? 2)Can the Nylon Plug fall apart, and will I need to replace it? 3)Do I need to flush the system out with anything in particular, and then Do I need to flush it with the coolant before filling it? 4)Is there a technique to follow? (I have read about filling almost to the top, turning the blower on to full heat, speed 2) and then gradually topping it up?) 5) What is the particular coolant required? Thanks Quote Link to comment Share on other sites More sharing options...
H3lly Posted December 27, 2010 Share Posted December 27, 2010 This is one of the easier jobs to do. There are some clips on youtube but this is one of the better ones. It's a US focus so drain plug will be on the other side. It isn't a complete tutorial but it will explain what you need to do. Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted December 27, 2010 Author Share Posted December 27, 2010 H3lly, did you perhaps mean to put in a link? Quote Link to comment Share on other sites More sharing options...
H3lly Posted December 27, 2010 Share Posted December 27, 2010 Here is a link from focushacks.com for this 'how to': http://www.focushacks.com/index.php?modid=50&ht=Cooling Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted December 28, 2010 Author Share Posted December 28, 2010 Thanks again H3lly, didnt see the videos attached through my works system, so thank you for that :) It seems that the focus uses 6 litres of coolant, just want to make sure as I can go to Halfords and purchase either Halfords 5 litres, but as Ford advised the temperature should be down to -37, does anyone know if flushing through all 7.3 litres with the Halfords above, will be as good as, or more poor than, forking out for the Motorcroft SuperPlus Antifreeze? Dont really want to flush out good, to put in lesser quality Quote Link to comment Share on other sites More sharing options...
