Tina Posted July 13, 2008 Share Posted July 13, 2008 Drivers door will not open how do I fix this? Quote Link to comment Share on other sites More sharing options...
delboy Posted July 13, 2008 Share Posted July 13, 2008 Drivers door will not open how do I fix this? try removing the door panel from inside the car then you should gain access to the lever that releases the dook lock. sounds like the bar that pulls & pushes the lock when using the handle has come off. Quote Link to comment Share on other sites More sharing options...
ColinFord Posted July 31, 2008 Share Posted July 31, 2008 Drivers door will not open how do I fix this? Use the handle. Quote Link to comment Share on other sites More sharing options...
delboy Posted August 1, 2008 Share Posted August 1, 2008 Use the handle. colin if you have nothing to say that can be of help then say nothing go to the joke saction if there is 1 for your so called funnies Quote Link to comment Share on other sites More sharing options...
ColinFord Posted August 1, 2008 Share Posted August 1, 2008 go to the joke saction if there is 1 for your so called funnies Cool, I'll check out the joke saction. But to be honest, did you say anything in your last post that could be of help either? Quote Link to comment Share on other sites More sharing options...
