flameowner Posted November 17, 2010 Share Posted November 17, 2010 Hi, I have an 06 Ford Fiesta 1.4 petrol. The engine management warning light is on permanently. It is misfiring and when I disconnect plug 3 it makes no difference to the running of the engine suggesting that this is the cause. When I disconnect the other plugs from the none spark plug end I see the spark jumping from the distributor block to the lead. I do not see this from the block to lead number 3. I am right in assuming the distributor block is at fault and if so do I have to go to a Ford dealer to get one? Also what it the block with the lead terminations called that used to be a distributor cap but is now an alluminum block / module. Thanks for any help. Quote Link to comment Share on other sites More sharing options...
fordpartsman Posted November 17, 2010 Share Posted November 17, 2010 Th item your are describing is called a called a coil pack. You can get these from both ford and from motor factors. But in honesty ford ones are 20x better Quote Link to comment Share on other sites More sharing options...
