jmurray01 Posted February 21, 2011 Share Posted February 21, 2011 The belt is slipping (making a chirping noise that gets closer together and faster the higher the engine RPM's), and it needs changing, so, is it hard ? I know the answer I'd give to a thread like this: Read a Haynes manual! But I don't have one just now :( Quote Link to comment Share on other sites More sharing options...
stef123 Posted February 21, 2011 Share Posted February 21, 2011 The belt is slipping (making a chirping noise that gets closer together and faster the higher the engine RPM's), and it needs changing, so, is it hard ? I know the answer I'd give to a thread like this: Read a Haynes manual! But I don't have one just now :( cant speak for your engine but generally speaking that are quite easy - providing you have enough access. do you know what kind of tensioner your car has? some have an auto type where as some have a manual type. Quote Link to comment Share on other sites More sharing options...
jmurray01 Posted February 23, 2011 Author Share Posted February 23, 2011 Being a pre-2000 car I would assume it would be a manual tensioner ? If so, is it easy to tighten the belt after fitting the new one ? Or will it be hard to adjust because of the tension of the belt itself ? Quote Link to comment Share on other sites More sharing options...
jmurray01 Posted February 28, 2011 Author Share Posted February 28, 2011 UPDATE: The chirp/squeak has gone! It was damp when it made the noise, and after sitting in the dry garage for 6 days the squeak has gone! :) Quote Link to comment Share on other sites More sharing options...
MartynS Posted February 28, 2011 Share Posted February 28, 2011 Wait till it rains :P Quote Link to comment Share on other sites More sharing options...
