Focus 1800 Zetec
25 replies to this topic
#16 pauls440
pauls440
    Member
  • New Member
  • PipPip
  • 24 posts
  • Name: Paul
  • Ford Model: focus 1800 16v zetec ghia
  • Year: 1999
Posted 16 January 2012 - 03:06 PM
Hi and thanks for the reply
well i don't think it was done by fords i have no paper work for it , the man i got it off said he had it done, if its not that what could it be ??????????????????
Have something to contribute?
#17 stef123
stef123
  • Management
  • 5,878 posts
  • Name: Stefan
  • Ford Model: Mondeo ST TDCI
  • Year: 2006
Posted 18 January 2012 - 09:53 AM
It's quite easy to screw the timing up if the locking kit isn't used correctly but I'm sticking with a vacuum leak or a split hose..
#18 whitelightning
whitelightning
  • Budding Enthusiast
  • 41 posts
  • Name: Jym
  • Ford Model: Ford Focus Zetec MK1 A blue one
  • Year: 1999
Posted 18 January 2012 - 05:05 PM
Hi. Ihave 1.8 '99 petrol zetec and share your problem with 'hunting' at low revs and occasional stalling, New Quality HT leads and plugs with correct gaps set seemed to sort the first time. iac valve the second time and lubing the throttle cable and now I think its just part of the focus make up. I'm having a play with a slight misfire now too so will let you know if its connected. Also try not to use supermarket fuel definatly makes a difference in the running.
#19 pauls440
pauls440
    Member
  • New Member
  • PipPip
  • 24 posts
  • Name: Paul
  • Year: 1999
Posted 18 January 2012 - 08:07 PM
hi thanks for the replys ,
could it be the airflow meter, or the cold start staying on ???? as im useing a lot of petrol
£20 and i get 96 miles :(
#20 pauls440
pauls440
    Member
  • New Member
  • PipPip
  • 24 posts
  • Name: Paul
  • Year: 1999
Posted 18 January 2012 - 09:04 PM
yes but dos your reves go up and down
#21 stef123
stef123
  • Management
  • 5,878 posts
  • Name: Stefan
  • Year: 2006
Posted 18 January 2012 - 10:49 PM
What happens if you unplug the maf sensor? A duff one will cause running issues...
#22 pauls440
pauls440
    Member
  • New Member
  • PipPip
  • 24 posts
  • Name: Paul
  • Year: 1999
Posted 20 January 2012 - 04:06 PM
focus 022.JPG focus 022.JPG Big thanks to stef123 give that man a cegar it is a air leak ,but i dont no ware it gos so help ,
#23 artscot79
artscot79
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 8,010 posts
  • Name: arthur
  • Year: 2006
Posted 21 January 2012 - 03:00 AM
TRY to the left of where youre hand is a black circular box it fits there by the look of it or behind the engine where ure hand is in the picture it will conect to a larger piece going into the engine next to a rubber hose with a bend in it that runs under the coil pack
#24 pauls440
pauls440
    Member
  • New Member
  • PipPip
  • 24 posts
  • Name: Paul
  • Year: 1999
Posted 21 January 2012 - 09:38 AM
Thanks Arthur thats a great help
#25 dexter666
dexter666
    Member
  • New Member
  • PipPip
  • 22 posts
  • Name: peter
  • Ford Model: focus 1.6 petrol mk1
  • Year: 2003
Posted 21 January 2012 - 11:34 AM
Do the revs hunt when car has been left for couple of hours? sounds like it could be cylinder head temperature sensor;not an expensive fix.
#26 pauls440
pauls440
    Member
  • New Member
  • PipPip
  • 24 posts
  • Name: Paul
  • Year: 1999
Posted 21 January 2012 - 02:54 PM
sorted :) :) :)
it was a vacum hose witch was in half, £27.50 from fords :o halfords petrol pipe £5.99
all i done was cut a pice out and glued in the petrol pipe sorted :D :D
thanks to all that replyed
Not what you're looking for?
