H8XME Posted April 1, 2012 Share Posted April 1, 2012 Hello I'm new to the forum as I just purchased my first focus. Need a bit of help with this noise? It sounds like the bush rubbers would spraying with oil solve the noise? Also is this common? Thanks Quote Link to comment Share on other sites More sharing options...
artscot79 Posted April 1, 2012 Share Posted April 1, 2012 is it the front? quite common if it is spray the tie rods with some 3 in 1 oil just dont get it on the tyres and brakes also do the lower wish bone bushes spray white grease is better i had it on mine but if you pop the bonnet open and look on the bulkhead you will find a thin drain tube for the water from the windscreen cover to drain see if it sits directly above the suspension or not if it does simply move it so it doesnt Quote Link to comment Share on other sites More sharing options...
