BadboyHouse Posted June 28, 2012 Share Posted June 28, 2012 Hi all. New member here. I put the car in the garage tonight having drove home from work. After I turned off the engine I got an "Engine oil Pressure Low" message come up on the centre LCD display. The message went off after about 20 seconds. I started the car back up but the message didn't reappear. I started the car back up about half an hour later, left it running for a minute or two and then switched off but the message didn't come backup after that either. I checked the oil dipstick just in case, and the oil was half way between min and max. This was after the engine had been off for about 30 minutes. It's a 59 plate 1.25 Style, first registered 30/07/09. I imagine it might have been a one off message perhaps some crap on a sensor or something? Just wondered if anyone had ever had the same problem? Quote Link to comment Share on other sites More sharing options...
james_60 Posted June 28, 2012 Share Posted June 28, 2012 Hi Unless you can get it to ford with the message still showing they wont give two hoots. All i can suggest is get that oil to the max and not a smidge over. see if it happens again. We both may end up having to change our own oil pressure switches by ourselves. Jamie Quote Link to comment Share on other sites More sharing options...
BadboyHouse Posted June 28, 2012 Author Share Posted June 28, 2012 Cheers. It didn't happen again after two engine restarts so I'll see if it happens again. If it does I'll stick some more oil in and go from there. Quote Link to comment Share on other sites More sharing options...
