L.e.d
#16
Posted 16 July 2012 - 01:40 AM
#17
Posted 16 July 2012 - 01:45 AM
As the 12v socket is located on the centre console not the cubby hole, as you say it's now blocked.
I was lucky enough to get one designed for the mk2, sorry I don't mean to rub it in.
#18
Posted 16 July 2012 - 11:48 AM
#19
Posted 16 July 2012 - 11:38 PM
http://www.ebay.co.u...=item4ab9c82458
#20
Posted 16 July 2012 - 11:54 PM
#21
Posted 17 July 2012 - 12:27 AM
#22
Posted 28 July 2012 - 05:27 AM
Everything was easy apart from getting the socket out of the old position.
I had a hell of a job removing the socket from the black sleeve it's held by in the old position due to a totally useless bulb holder which does not have a bulb or contacts in and being black would not let light through anyway.
Nothing that a bit of butchery with a pair of pliers didn't solve in the end.
Now fitted and looking good but i will probably have to revisit the project in the next couple of days as i need to move my aux cable as it comes out just above the flap and gets in the way.
I reckon that if i put it through the same route as the 12v socket wiring then it will look smarter and mean no loose wires showing when the flap is closed.
Another good thing is that the 12v feed for the socket light dims with my dash lights and also is perfectly positioned to allow a tap off if i ever get around to fitting an illuminated gear knob.
I'd just need to find a suitable earth wire/point.
Anyone know which of the wires to the 12v socket is the ground line?
#23
Posted 28 July 2012 - 07:44 AM
if the wires are
1 x Orange
1 x Black
then the black is the earth mate but to be sure,
you could wire up a light or led,
then put the negative of the light to the body of the car then the positive to the black cable on the 12v socket,
if the bulb illuminates then its not the black
#24
Posted 28 July 2012 - 02:37 PM
Ohhhh, that's different than the one I bought, mine is just a full storage compartment with no fixing for the 12v socket. So mine is now defunct behind the garage door :-/ suppose I'll live lol.
Alright mate have you seen what I've done to mine? Easy job and now I've got my power socket back in the cubby hole without needing to relocate it, I've got the same garage door as you.
#25
Posted 21 February 2013 - 02:56 PM
okay guys i plan to add and led in the rear of the car that useless cubby hole behind the armrest
What is this plastic panel called? Is it easy to find on on ebay?
#26
Posted 21 February 2013 - 03:59 PM
#27
Posted 21 February 2013 - 04:47 PM
