Escort Mk6 Overheating -- Cooling Fan Not Working!
2 replies to this topic
#1 spud1962
spud1962
    Newbie
  • Pip
  • 2 posts
  • Ford Model: Escort MK6 1.8 Ghia 16v Zetec
Posted 25 August 2012 - 09:13 PM
Please can anyone help?
Just lost the use of radiator cooling fan on my mk6 1.8 16v escort ghia, causing the engine to overheat.Posted Image
I think i have discovered the correct sensor/switch connected to a coolant pipe underneath
a short right angled air intake pipe which i have temporarily removed
Does anyone know how to test or bypass the temperature switch at the source?
How should I test if the fan itself is not kaput?
When disconnected from the switch, The loom end has 4 wires. The terminals are marked 1 to 5 with no connection to terminal 2. if i bridge the switch at this point, surely this will activate the fan?
Not sure how to discover which of the connections when bridged will allow the fan to operate.
Note: If I disconnect the switch and run the engine - the fan does not operate either, but I'm not
sure if it should anyway ?
#2 oilburner79
oilburner79
  • Members via Twitter
  • 109 posts
  • Name: darren
  • Ford Model: Focus Zetec Collection
  • Year: 2000
Posted 25 August 2012 - 09:24 PM
You need to bridge the fan switch it's usually located on the radiator
#3 spud1962
spud1962
    Newbie
  • Pip
  • 2 posts
Posted 25 August 2012 - 09:28 PM
Yes, true, a lot of cars do - but i think the switch is located elsewhere (see above)
