My eldest son has recently purchased a 1.6 Zetec S on an '05 plate and is already regretting it. The cars main problem, is that when driving off in 1st gear, he gets varying degrees of engine judder coming through. The parts on the car that has been replaced by him or the previous owner are as follows:
- Gearbox mounts.
- Off side engine mount.
- Clutch replaced 10,000 miles ago.
- Fuel filter replaced as part of a service 20,000 miles ago.
I've checked the ECU for fault codes and none have been logged, so whatever is causing this problem, isn't being identified by the ECU. Any help, tips or advice on the next thing to try would be gratefully received.
Cheers
