1998 Fiesta Engine Problems! Please Help!
4 replies to this topic
#1 Cooze
Cooze
    Newbie
  • Pip
  • 2 posts
  • Ford Model: 1.25 Zetec
Posted 20 December 2012 - 07:26 PM
Hi guys,
Ive been having trouble with my 98 1.25 zetec ever since i bought it in Feb last year!
Here are my 2 main problems;
1) My car seems to be drinking oil at a fast rate, since feb last year ive had to buy and top up the oil about 7 - 8 times. Iv even had an oil change but nothing has changed. Theres no sign of leak and the multiple mechanics its been too have said they cant find anything wrong as its not leaking or smoking etc. Surely its not normal to top up every month?
2) By far the worse problem, my car seems to stall and completely cut out on an often and random basis. At first i thought its my driving as its my first car but my gf has also experienced it cut out. I think it has something to do with the idle air control valve. The problems i face is when idle the needle on revs is supposed to be about 1.1 as i believe but mine is always under 1, usually 0.9.
When i approach corners at low speed or junctions the car just lockes up and cuts out! no warning like chuddering asif its my driving. The only way i know is because the steering wheel locks up and battery light comes on. Ive noticed that the rev needle is all up and down like mad when i come to idle and this is why i believe this is the problem.
Its been to 3 garages so far and nothing has fixed this problem? Could i just need to replace the valve completely as 2 of the garages have just cleaned the valve and it seems to work ok for a few weeks at the start but not even cleaning seems to help now?
Please help if you can as this is costing me a small fortune!!
Thanks guys!
#2 DieselPig
DieselPig
  • 206 posts
  • Ford Model: Fiesta Zetec 1.6 TDCi
  • Year: 2011
Posted 20 December 2012 - 11:15 PM
How many miles has the car done? If its drinking oil and there are no leaks I'd get rid of it.
#3 Magenta
Magenta
  • 427 posts
  • Name: Alan
  • Ford Model: Fiesta Mk7 Titanium 1.4 Auto - Marello
  • Year: 2009
Posted 21 December 2012 - 10:31 AM
I'm afraid DieselPig is probably right on the oil consumption matter but it's a bit odd that there are no leaks and no smokey exhaust to show the oil is being burnt. Is the inside of the tailpipe thick with black soot ? I had a car that was losing oil into the coolant due to a blown gasket but I assume you would have noticed the contaminated coolant.and the rising level in the expansion tank.
#4 Cooze
Cooze
    Newbie
  • Pip
  • 2 posts
Posted 21 December 2012 - 06:17 PM
Its done 77k so its not too bad considering its age? I will check the tail pipe tomorrow as its too dark now. I suspect you guys are right that it could be the age of it and because its an old car. Im planing on getting rid of it in March but i have my MOT coming up in Jan and dont want a huge bill lol
#5 DieselPig
DieselPig
  • 206 posts
  • Year: 2011
Posted 21 December 2012 - 08:18 PM
Assuming you bought this car second hand can you prove 77K is the original mileage, bit low for a `98 car!
