Help! With Illuminated Cigarette Lighter
8 replies to this topic
#1 markw96
markw96
  • Budding Enthusiast
  • 58 posts
  • Name: Mark
  • Ford Model: Focus 1.6 tdci titanium (DPF)
Posted 02 March 2013 - 03:32 PM
Im trying to change the standard cigarette lighter on a focus 2.5 to fit an illuminated one, but im having a couple of problems, how on earth do i remove the cigarette lighter surround?
https://www.dropbox.... 15.13.36.jpg?m
https://www.dropbox.... 15.13.30.jpg?m
and also where can i connect these extra wires for the illumination??
https://www.dropbox.... 15.13.46.jpg?m
thanks in advance
Have something to contribute?
#2 Preee
Preee
    Ford Fruitcake
  • 4,374 posts
  • Name: Paul
  • Ford Model: Focus Tit X Mk3.5 | Fiesta Zetec Mk7
  • Year: 2015
Posted 02 March 2013 - 05:11 PM
You should see some tabs on the side's that just allow you to unclip it , the lighting can be connected to the orange and black wires behing the heated screen buttons
#3 vince_13
vince_13
    Vince
  • True Ford Enthusiast
  • 542 posts
  • Name: Andrew
  • Ford Model: Focus Zetec
  • Year: 2009
Posted 02 March 2013 - 05:28 PM
what i did to remove the cig lighter, was to turn the plastic trim upside down (cig lighter bottom pointing up) apply some pressure onto the cig lighter downwards, at the same time as pull the tabs out on either side with a screwdriver, do 1 side then the other, it doesn't take much, then pull it out from the top
#4 markw96
markw96
  • 58 posts
  • Name: Mark
Posted 02 March 2013 - 05:51 PM
After all that the illuminated one ive got dont !Removed! fit!!
Can anyone point me in the direction of one that will fit???
thanks
#5 Preee
Preee
    Ford Fruitcake
  • 4,374 posts
  • Name: Paul
  • Year: 2015
Posted 02 March 2013 - 06:18 PM
As the top will cover about 2mm around the top can you not make the hole bigger? , easy way if your buying a new one is just measure the OEM one and compare online
#6 markw96
markw96
  • 58 posts
  • Name: Mark
Posted 02 March 2013 - 06:22 PM
This is the one i bought
http://www.ebay.co.u...984.m1439.l2649
the problem being though that i couldnt get the red illumintaed plastic part to fit into the original silver plastic bezel type part that held the original cigarette lighter if you know what i mean
#7 Preee
Preee
    Ford Fruitcake
  • 4,374 posts
  • Name: Paul
  • Year: 2015
Posted 02 March 2013 - 06:27 PM
Do you need that section ? , will it not fit without the bezel
#8 artscot79
artscot79
  • PipPipPipPipPip
  • 7,995 posts
  • Name: arthur
  • Year: 2006
Posted 02 March 2013 - 06:34 PM
Easiest method is to take one out a scrap car behind the kick panel drivers side theres an orange wire with a plug on it taped up thats the illumination wire you wont get the illuminated ring on the original its a smaller one that fits im sure
#9 Stoney871
Stoney871
    Resident Peacekeeper
  • Super Mod
  • 18,561 posts
  • Name: Clive
  • Year: 2015
Posted 03 March 2013 - 09:30 AM
The silver bezel is bigger in diameter than the standard Ford illuminated socket bezel by about 6mm.- (34mm compared to 40mm).
If you could find a 12v socket that was 35mm to fit in the hole on the console trim but had a lip of 36mm and above then you should get a firm fit.
The original ford 12v socket fitting itself is 29mm by itself so basically the socket you bought is about the same size as the original socket without any illuminated sleeves or bezel.
Not what you're looking for?
