Mondeo Problem Help !
21 replies to this topic
#16 spannerman
spannerman
    Member
  • PipPip
  • 10 posts
  • Name: ian
  • Ford Model: escort
  • Year: 2000
Posted 25 March 2013 - 08:27 PM
hi there.  what gap do you think you have now between the sensor and the timing lugs. I have a similar problem, but do not want to damage my crank sensor. in reply to your own problem, have you thought about a compression test
#17 hubby1959
hubby1959
  • 71 posts
  • Name: Neil
  • Ford Model: Mondeo MK 2
  • Year: 1999
Posted 25 March 2013 - 08:35 PM
It's only smoking cos no2 pot isn't working, once you get that done it should stop, try loosening the fuel feed nut slightly on no2 as it might be airlocked
#18 cliffy 71
cliffy 71
    Member
  • PipPip
  • 11 posts
  • Name: cliff
  • Ford Model: mondeo 20l tdci 130
  • Year: 2003
Posted 25 March 2013 - 08:46 PM
But surely if it's smoking fuel is going into the cylinder but not igniting ? As for a compression test the engine ran perfect in the car it was taken out of. Could glow plug cause it
#19 cliffy 71
cliffy 71
    Member
  • PipPip
  • 11 posts
  • Name: cliff
  • Year: 2003
Posted 25 March 2013 - 08:49 PM
Sorry the crank sensor goes as far down as it can . We had it about 3 mm from fully in and it wouldn't go .
#20 cliffy 71
cliffy 71
    Member
  • PipPip
  • 11 posts
  • Name: cliff
  • Year: 2003
Posted 25 March 2013 - 09:01 PM
Oh yes a big warning ! When working on crank shaft sensor fill the hole in with some tissue etc , I dropped the bolt into the gear box and had to partially remove the box I was not happy !
#21 stooge75
stooge75
  • 218 posts
  • Ford Model: Mondeo tdci zetec
Posted 25 March 2013 - 10:02 PM
ohhhh.that would be a right downer.wonder how many have done same thing & said "Oh b*llox,I'll just leave it n buy another one"
#22 cliffy 71
cliffy 71
    Member
  • PipPip
  • 11 posts
  • Name: cliff
  • Year: 2003
Posted 27 March 2013 - 06:04 PM
Still no joy with this car, cylinder no 3 still off and smoking like hell, iv checked glow plugs, is there a way to test the injector or what should my next step be cheers
