salsheikh Posted May 19, 2013 Share Posted May 19, 2013 Well, i undid all 4 nus and removed the handbrake trim/cover and the gearstick trim/cover but could not remove the centre console from its position. I moved it forwards/backwards but could not get it to come out so that i could replace it with an armrest version? any ideas please? oh, to note - on the armrest version there is a plug to power the cig lighters but no plug on my centre console trim. how do i connect this up? armrest plug.bmp Quote Link to comment Share on other sites More sharing options...
Postie123 Posted May 19, 2013 Share Posted May 19, 2013 That plug is for the the 12v plug under the arm rest and the aux if you have that under the arm rest. Are you fitting a mk2.5 console to a mk2 or something? Quote Link to comment Share on other sites More sharing options...
salsheikh Posted May 19, 2013 Author Share Posted May 19, 2013 its from a 2.5 and going into a 2.5 Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted May 19, 2013 Share Posted May 19, 2013 I believe that plug also carries the aux and usb feeds. Might show up on Microcat. Quote Link to comment Share on other sites More sharing options...
Hell5200 Posted May 19, 2013 Share Posted May 19, 2013 When I installed mine the connector was taped up behind the footwell was wrapped in gray foam. Quote Link to comment Share on other sites More sharing options...
salsheikh Posted May 20, 2013 Author Share Posted May 20, 2013 so how do i remove the current centre bit so i can put my new armrest in? Quote Link to comment Share on other sites More sharing options...
Hell5200 Posted May 20, 2013 Share Posted May 20, 2013 There are two bolts on the front and two at the back and you have to unclip the footwell panels and take the handbrake surround off aswell, then it's abit fiddly trying to get it to go past the handbrake. Quote Link to comment Share on other sites More sharing options...
