genericflipper Posted August 3, 2013 Share Posted August 3, 2013 I have a problem where the engine seems to 'race' when accelerating when coming out of a roundabout, or turning, or climbing a hill. it takes a few seconds before the power reaches the wheels. it doesnt happen all the time. it feels a bit like an automatic gearbox when changing down to overtake. the clutch seems to be fine. any ideas much appreciated Quote Link to comment Share on other sites More sharing options...
wase16ll Posted August 4, 2013 Share Posted August 4, 2013 sounds to me that the clutch isnt as fine as you think....could be slipping Quote Link to comment Share on other sites More sharing options...
artscot79 Posted August 4, 2013 Share Posted August 4, 2013 clutch slip as above hence the engine racing my clutch felt perfectly fine till one day changing gear it wouldnt go when ford opened the box the clutch was in pieces in the box it was so worn Quote Link to comment Share on other sites More sharing options...
STEADS Posted August 4, 2013 Share Posted August 4, 2013 Ditto does sound like clutch slip to me as we'll. Quote Link to comment Share on other sites More sharing options...
genericflipper Posted August 4, 2013 Author Share Posted August 4, 2013 Thanks for the advice, is it possible to adjust the clutch or is it likely to need replacing? Quote Link to comment Share on other sites More sharing options...
wase16ll Posted August 4, 2013 Share Posted August 4, 2013 will need renewing Quote Link to comment Share on other sites More sharing options...
genericflipper Posted August 4, 2013 Author Share Posted August 4, 2013 obviously clutch wear depends on use but theres only 86000 on the clock. and it feels ok, and stalls the engine when tested. is there anything else it could be? Quote Link to comment Share on other sites More sharing options...
wase16ll Posted August 4, 2013 Share Posted August 4, 2013 if the engine is revving faster than the car...its the clutch... if you drive up a steepish hill, go from second to fourth, accelerate hard...if engine races, even brieflly, clutch is slipping Quote Link to comment Share on other sites More sharing options...
genericflipper Posted August 12, 2013 Author Share Posted August 12, 2013 thanks all - it was the clutch, now sorted.... Quote Link to comment Share on other sites More sharing options...
