garytaxi Posted November 17, 2013 Share Posted November 17, 2013 Hi I hope I am on correct forum as new to this one, I just wondered if anyone has had the problem that my car is having, I have a 2012 mondeo zetec 2.0 litre diesel. it is used as a taxi and has 26000 miles on clock, I have noticed on occasion that car idles poorly with rev counter jumping from the usual 750rpm idle up to around 850 and down to 500rpm, when this is going on car seems to be backfiring slightly this can last for several minutes and then car return's to usual idle when this first happened I put it down to dpf regeneration, ? but it seems to be happening more often now at first it was once a week or so, then twice but yesterday it happened again And the day before, so am getting concerned , it will clear up if you drive in a lower gear for a mile or so But is becoming a pain apart from that I like car. am taking it to dealers soon as due oil change shortly Quote Link to comment Share on other sites More sharing options...
btmaldon Posted November 17, 2013 Share Posted November 17, 2013 I am no expert on diesels, but I would think a fuel filter change may help. Quote Link to comment Share on other sites More sharing options...
stooge75 Posted November 17, 2013 Share Posted November 17, 2013 your EGR could be sticking maybe,but you'd have to check.or fuel filter ,mmm. unusual for taxi driver to give up a car at 26k unless he knows something you dont,maybe. i would(as btmaldon says),check filter,EGR valve,then if that doesnt work,get someone to plug it in toFord IDS,& see what comes up. cant see it being anything severe though unless said taxi drivers been using bio-diesel etc.(& a lot do,up here). could be something silly like a sensor,but really,you're only going to find that out if you plug it in. other day I saw a BMW with very similar symptoms to you,& it WAS his DPF. Mechanic stuck it in a bucket of cleaner for a day,then revved the hell outta car,& problem solved.i was amazed at the stuff that came outta the exhaust when revving it to clean it Quote Link to comment Share on other sites More sharing options...
mick85 Posted November 17, 2013 Share Posted November 17, 2013 I would say u need a PCM upgrade u would need go main dealer common problem Quote Link to comment Share on other sites More sharing options...
garytaxi Posted November 18, 2013 Author Share Posted November 18, 2013 I am no expert on diesels, but I would think a fuel filter change may help. Thanks for advice it had crossed my mind about filter , but think I will wait to see what dealer says as still under warranty your EGR could be sticking maybe,but you'd have to check.or fuel filter ,mmm. unusual for taxi driver to give up a car at 26k unless he knows something you dont,maybe. i would(as btmaldon says),check filter,EGR valve,then if that doesnt work,get someone to plug it in toFord IDS,& see what comes up. cant see it being anything severe though unless said taxi drivers been using bio-diesel etc.(& a lot do,up here). could be something silly like a sensor,but really,you're only going to find that out if you plug it in. other day I saw a BMW with very similar symptoms to you,& it WAS his DPF. Mechanic stuck it in a bucket of cleaner for a day,then revved the hell outta car,& problem solved.i was amazed at the stuff that came outta the exhaust when revving it to clean it Thanks I seem to have confused with the way I wrote post , I am a Taxi driver, and have only had car 9000 miles But I will have filter renewed and get them to check egr and if required get them to stick it on their equipment I would say u need a PCM upgrade u would need go main dealer common problem Cheers help much appreciated I have decided to contact dealer So hopefully it will be something as simple as you have suggested Quote Link to comment Share on other sites More sharing options...
