martyntdci Posted January 17, 2014 Share Posted January 17, 2014 evening all, its almost been 2 yrs now since my last brake fluid change, and i forgot what i used. i know in the manual it says either ford or super dot 4.... but which one? and also in the handbook it doesnt stste the capacity. i take it 2ltr will be enough for a full empty and change would it be this fluid :- http://www.eurocarparts.com/ecp/c/Ford_Focus_1.8_2007/p/car-accessories/engine-oils-and-car-fluids/auxiliary-fluids/brake-fluid/?130339010&0&cc5_179 this as its for esp braking:-http://www.eurocarparts.com/ecp/c/Ford_Focus_1.8_2007/p/car-accessories/engine-oils-and-car-fluids/auxiliary-fluids/brake-fluid/?524770042&0&cc5_179 or this, but it has a different compound :-http://www.eurocarparts.com/ecp/c/Ford_Focus_1.8_2007/p/car-accessories/engine-oils-and-car-fluids/auxiliary-fluids/brake-fluid/?524770272&0&cc5_179 any help would be much appreciated, and thanks in advance :-) Quote Link to comment Share on other sites More sharing options...
mick85 Posted January 18, 2014 Share Posted January 18, 2014 Once it dot 4 it be grand an 2 litres be plenty for flush Quote Link to comment Share on other sites More sharing options...
stef123 Posted January 18, 2014 Share Posted January 18, 2014 I use a pressure bleeding kit that holds 2 litres, even with that I would be there all day! A litre will be plenty Quote Link to comment Share on other sites More sharing options...
JW1982 Posted January 18, 2014 Share Posted January 18, 2014 After retrofitting the rear disc brakes and the IVD system (Intelligent Vehicle Dynamics which contains ABS,ESP and TCS)my brake system was completely drained. 1 Liter of brake fluid was just enough to fill and bleed the system completely with a power bleeder. So 1 liter must be enough to change the brake fluid. On the other hand brake fluid is relatively cheap and to make absolutely sure you have enough you could buy 2 cans of 1 Liter. An unopened can of brakefluid can be kept for several years so you could use it the next time you change the brake fluid. Quote Link to comment Share on other sites More sharing options...
martyntdci Posted January 18, 2014 Author Share Posted January 18, 2014 went to local ford dealers this morning, 2 bottles of dot 4 1ltrs cost just over £11 inc vat, was quite chuffed thought it would of been over £20. hope weather hold out for tomorow..... Quote Link to comment Share on other sites More sharing options...
south_bound Posted January 18, 2014 Share Posted January 18, 2014 How important is it to keep to the 2 year change interval? I stopped going having the dealer servicing when the warrenty ran out 3+ years ago so mine definately hasn't been done since then and I'm not noticing anything different while driving or stopping. Quote Link to comment Share on other sites More sharing options...
martyntdci Posted January 18, 2014 Author Share Posted January 18, 2014 we had the car 2 yrs ago, did it then as i didnt hav any back service knowledge of the car. i just go by the manual just because of moisture in the fluid when its breaks down...... oil every 4-5k ish. fuel filter once a year. gearbox fluid got done approx a yr ago. just got do the coolant when weather warms up..... Quote Link to comment Share on other sites More sharing options...
