stansnuts Posted April 27, 2014 Share Posted April 27, 2014 Hi everyone, apologies if this has already been covered elsewhere but can anyone please tell me how I remove the engine cover/air box on a 2002 duratec engine. I have changed the air filter and want to change the plugs and leads but without this !Removed! cover/box out of the way it's a job strictly for a gynaecologist and I suffer from sausage finger syndrome so need all the help I can get! Quote Link to comment Share on other sites More sharing options...
Dan62 Posted April 27, 2014 Share Posted April 27, 2014 \ Quote Link to comment Share on other sites More sharing options...
stansnuts Posted April 27, 2014 Author Share Posted April 27, 2014 Stiff! Surely it's fastened on somehow, I tried brute force and the whole engine and airbox were just moving about on the engine mountings and suspension! Are you sure there are no hidden fixings I don't want to damage anything as it's my daughters car? Quote Link to comment Share on other sites More sharing options...
stansnuts Posted April 28, 2014 Author Share Posted April 28, 2014 OK thanks for the info and the diagram, appreciate it, could not find anything on the web/net/ you tube about this particular air box, every other ford one is on there but not this one, thanks again for your help. Quote Link to comment Share on other sites More sharing options...
Dan62 Posted April 28, 2014 Share Posted April 28, 2014 \ Quote Link to comment Share on other sites More sharing options...
stansnuts Posted April 29, 2014 Author Share Posted April 29, 2014 All sorted now, thanks for all your help. Discovered a perished crank breather hose underneath the box once I got it off and also no 1 and no3 HT leads had no heat shields on, is this usual? Also found a water leak from the rear of the engine block, right hand side as you look at the engine from the front of the car, is the water pump located in this area? Quote Link to comment Share on other sites More sharing options...
Dan62 Posted April 29, 2014 Share Posted April 29, 2014 \ Quote Link to comment Share on other sites More sharing options...
AShpod Posted November 4, 2014 Share Posted November 4, 2014 Hello Dan62. Can you repost please the diagram. I have the same problem as stansnuts and i can't figure out how to remove the air box on the same engine. I can't see your previous posts, only some slashes( / ). Thank you. Quote Link to comment Share on other sites More sharing options...
MontiVideo Posted March 20, 2015 Share Posted March 20, 2015 Sorry guys I have the same problem with my 2002 Fiesta with the engine cover but unfortunately can't see your ansewer to the query 1 Quote Link to comment Share on other sites More sharing options...
Dan62 Posted March 20, 2015 Share Posted March 20, 2015 Here you go, it may be tight but it does just lift off. 1300_air.pdf 1 Quote Link to comment Share on other sites More sharing options...
MontiVideo Posted March 21, 2015 Share Posted March 21, 2015 Thanks for your diagram although I took this car to two local garages where none of the mechanics knew how to remove this cover which I was amazed at. I could see if it was an obscure type of car but a Ford Fiesta?. Are you sure that once these pipes are disconnected that the housing just lifts off. I had another try this morning and the entire engine was lifting trying to pull it off. Quote Link to comment Share on other sites More sharing options...
Dan62 Posted March 21, 2015 Share Posted March 21, 2015 Its mounted on 4 studs, their positions are indicated by the arrows on the diagram, the cover has rubber grommets and its these grommets being tight that is the problem. Try lifting one corner at a time as indicated by the arrows. Might help if you can get some wd40 sprayed underneath the housing onto the grommets... if possible. Quote Link to comment Share on other sites More sharing options...
MontiVideo Posted March 21, 2015 Share Posted March 21, 2015 Cheers job done .. you would never believe how tight those rubber grommets were, you could almost swear they were bolted down. Thanks again much appreciated. Quote Link to comment Share on other sites More sharing options...
AliKarimilangroodi Posted July 20, 2020 Share Posted July 20, 2020 They are bolted down somewhere. I have broken those plastic locks, but the top still won't come out. Quote Link to comment Share on other sites More sharing options...
Tech1975 Posted May 13, 2021 Share Posted May 13, 2021 Dan62 Thank you so much !!!!! Your linked PDF was spot on, I couldn't believe how easy it was to remove(considering I'm an IT Professional 😲)! I was honestly expecting hex screws, bolts and clips. My little fiesta is my 'work horse' that has never failed me apart from this current small water leak which I needed to remove the box in order to fix. (My weekend car is a Jap import MX5 MK1 Eunos!) I'll certainly pop back here if I need any help on the 'work horse' in the future. Again, many thanks Dan62 👍 Quote Link to comment Share on other sites More sharing options...
