Tsumeb13 Posted April 30, 2014 Share Posted April 30, 2014 I have the above engin and was hoping to find someone that knows this engine very well. I am having a small problem with it, in that - when I set the valve clearances to the suggested 30mm inlet and 55mm outlet - colde, I get a tapping sound on the right bank - (cylinders 1, 2 and 3). When I remove the tappet cover and adjust while idling, I think I make the valve gaps too small, as the right exhaust pipe stays cold, while the left one is allready warming up?? What can be the root of this problem? Please assist Ray Quote Link to comment Share on other sites More sharing options...
dave h Posted April 30, 2014 Share Posted April 30, 2014 Hi mate I am trying to adjust the tappets on mine, do you know the correct sequence for adjusting them please. Thanks Dave Quote Link to comment Share on other sites More sharing options...
Tsumeb13 Posted May 1, 2014 Author Share Posted May 1, 2014 Hi there Dave, I follow the following sequence: No 5 cylinder rock - Adjust no 1 cylinder, No 3 cyl rock - adjust no 4, No 6 cyl rock - Adjust no 2, No 1 cyl rock - adjust no 5, No 4 cyl rock - adjust no 3 and No 2 cyl rock, adjust no 6 cylinder. I adjust when engin cold. Hope you come right! Quote Link to comment Share on other sites More sharing options...
dave h Posted May 1, 2014 Share Posted May 1, 2014 Hi thanks for the reply but that sequence is for the 2.3 and 2.8 cologne V6 engines which are different to the 3.0 litre Essex. Might be why your tappets are rattling Thanks Dave Quote Link to comment Share on other sites More sharing options...
